how much slip does my yoke need - JeepForum.com
post #1 of 2 Old 04-24-2010, 09:07 AM Thread Starter
mikeg281
specificly how much compression should I have from an at rest position. After the sye install the shaft has plenty of outward travel but maybe a half inch of inward. Ot doesn't feel like it bottoms out though so maybe is just has a butt load of grease. Its a tom woods kit with a rubber boot over the yoke so I can't tell by looking at it what point of its travel its at.
Mike
mikeg281 is offline
post #2 of 2 Old 04-24-2010, 10:28 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Following my SYE, I had an XJ CV shaft cut and balanced for my new rear drive shaft. The driveline shop set my slip yoke at 1 1/4" extended in the "at rest" position. This means I can compress 1 1/4 inches if needed.
No issues yet at close to 2 years.
You can call Tom Woods and ask specifically, he'll tell you.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
Will This Slip Yoke Fit?? RockShoxTora YJ Wrangler Technical Forum 10 08-09-2009 04:26 PM
Exploded my slip yoke housing and pinion yoke. durangoyj YJ Wrangler Technical Forum 53 01-12-2009 02:58 AM
slip yoke? jpl291 TJ Wrangler Technical Forum 7 08-18-2007 07:21 AM
Slip yoke JpnFirefighter YJ Wrangler Technical Forum 8 12-23-2006 03:05 PM
CV with a slip yoke? Mark_ZZ3 YJ Wrangler Technical Forum 0 08-20-2006 12:01 PM
