#1 | |
How much should I lower it...
Now that I got your attention
![]() I think I am going to start with .75" and hope the springs sag a little... the front shackles are being cut down already. and the rears are next. I really am digging the stance! I can't wait to get this bugger back on the road. It has been down for awhile. Though it will be a little bit before I can get the front axle re-geared to 4.88. The first picture shows the axle I originally installed (LP HD D44) I just sold that because the lockouts were stupid expensive, smaller axle tubes, and the LP. My buddy ran and picked up the HD HP D44 today for me... gotta throw that in and see where I stand. I already have better lockouts for it. Here are the pics... ![]() ![]() yanked ![]() new ![]() My buddy and I are doing the rust repair while we are at it.... ![]()
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies TRAIL TESTED (currently under the knife) 1946 CJ2A, 225 V6. mild lift - TIME TESTED 1966 M416 1/4 ton Military Trailer -- WAR TESTED Full Page Club member #004 Green Jeep Club Member #005 |
#2 |
don't fear the Jeeper
Holy rust, Batman. Time for some POR!
![]() How tall are those shackles, now? being soa, I would'nt make more than .5" over. ![]() ![]()
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <>< |
#3 | |
IIRC they were 2" longer then stock POS shackles. My buddy called and said that he took 1.5" off with the plasma cutter, cut them apart and is redoing them all nice, so there should end up being minimal lift out of the shackles. Need to make my shafts, install an SYE, and order the steering parts and I should be good to go (not that order) ![]() I'll need a traction bar, but I can do that a little later this summer when I have more of the wedding stuff out of the way...
#4 | |
As a former (40 Years) Michigan resident I can say from experience Michigan Sucks.
I bought my 92 in 2004 and it didn't have much rust but since I moved to New Mexico the rust went into remission. Don't ya just love those car turds that drop on the floor or you if you're under it. Quote:
All other things being equal, the simplest solution is the best. Ich liebe meinen Jeep! |
#5 | |
91 yj, 4.0, AX15, SOA, 8.8 rear, 4.88 gears, 2.5 inch springs front, m.o.r.e shackle reversal, m.o.r.e shock hoops, 3 inch springs in rear, bilstein 5150's, shock bar, m.o.r.e traction bar, lockers, m.o.r.e high steer, SYE, old school bronco cv shaft, tube fenders, 36 inch tsl's |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
