How much play is too much play? - JeepForum.com
post #1 of 9 Old 10-11-2011, 11:35 AM Thread Starter
bluedaffy
I read somewhere that when you lift a vehicle there is a certain amount of play in the steering that you will inquire everytime. Is this true?
I have (estimating) about 2" of play in my steering on my YJ. I have gotten used to it over time but I would like to minimize it for my wife. I want her to feel safe while driving it and not have to white knuckle when going highway speeds.
And if it were a perfect situation, even though I'm used to it,I would like it tight as well.
Thanks
bluedaffy is offline
post #2 of 9 Old 10-11-2011, 12:52 PM
moonshinefuel
What happens is the angle of the drag link increases with a lift. It effects the steering geometry, how it behaves. 4 inch lifts generally come with a pitman arm drop. Get the same level on the drag link as stock level from factory, if you can. I think generally that's the idea.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 9 Old 10-11-2011, 12:56 PM Thread Starter
bluedaffy
My lift is 2.5" is that enough to warrant the new parts?
post #4 of 9 Old 10-11-2011, 10:38 PM
moonshinefuel
No. Not a pitman arm drop. Not for 2.5" lift. There is a thread going on right now about a tie rod flip kit. That's a win win for what you are trying to accomplish.
Bow Hunting
post #5 of 9 Old 10-11-2011, 10:54 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
If you have 2" of play in your steering wheel, I would look at worn components. Most likely it is your lower steering shaft (The shaft that connects the firewall to the steering box). This part has two u-joints that tend to go bad.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #6 of 9 Old 10-11-2011, 11:05 PM
AnonymousD
How hard are these to change?
AnonymousD is offline
post #7 of 9 Old 10-12-2011, 10:52 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Pretty easy. It'll probably be frozen due to rust on the slip joint, so I cut mine in half, and loosened each end's pinch bolt. Fell right off.
-Matt
White '94 YJ Sport
UltimatE is offline
post #8 of 9 Old 10-14-2011, 08:47 AM Thread Starter
bluedaffy
Okay great, thanks. I'll look into getting a replacement. I know you wrangler folk out there must have an opinion on the best place to shop for these kinds of things (or steering shafts particularly)... so please offer your opinion regarding a quality online parts store.
post #9 of 9 Old 10-14-2011, 11:16 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Quadratec has the best price on this part that I can find.
http://www.quadratec.com/products/56113_02.htm
-Matt
White '94 YJ Sport
UltimatE is offline
play , steering , steering box
too much play RedWind YJ Wrangler Technical Forum 3 01-09-2009 03:11 PM
$5g To Play With zbob TJ Wrangler Technical Forum 14 08-24-2008 07:23 PM
Too much play? afguy TJ Wrangler Technical Forum 5 09-13-2007 10:08 AM
How much play? that_1_guy YJ Wrangler Technical Forum 3 08-23-2005 11:43 AM
