How much lift spring? - JeepForum.com
post #1 of 7 Old 02-11-2013, 06:54 PM Thread Starter
Shadownwpa
I'm getting ready to pull this body lift and replace it with springs and maybe shackles for the suspension lift... any recommendations? I'm guessing 3" or 4" as i want the same height over the 31s?
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #2 of 7 Old 02-11-2013, 07:00 PM
giggityjeeper
3" no one makes a 4"
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #3 of 7 Old 02-11-2013, 07:09 PM Thread Starter
Shadownwpa
I figured that's what the body lift is, more specific... I'm looking for recommendation on spring with or without shackle lift to replace it. Is there any advantage to longer shackles in addition to springs or does all spring work better?
post #4 of 7 Old 02-11-2013, 07:10 PM
Mark05059
its a 3 inch body lift... I would go go with 4" lift that is NOT made by rough country...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 7 Old 02-11-2013, 07:22 PM
jcmooreusmc
Do you have plans to put fender flares back on? If you plan to stay at 31s, then I'd run a 3" lift. You could do a 2.5" lift (OME,RE,etc.) at first, and then throw some 1/2" booms on there if you wanted to gain more height. Just my opinion, but it really depends on what your future intentions are w/ the Jeep.
jcmooreusmc is offline
post #6 of 7 Old 02-11-2013, 07:25 PM Thread Starter
Shadownwpa
Originally Posted by jcmooreusmc View Post
Do you have plans to put fender flares back on? I would recommend a 3" lift w/ 31s.
I'm planning some homemade tube fenders.
post #7 of 7 Old 02-11-2013, 07:53 PM
jcmooreusmc
Keep in mind that those flatty fenders will open the front up more. Here's some pics of mine. The first one is w/ 2.5" springs, 1" shackles, and 31" tires w/ stock flares that were trimmed. The second is the same setup, only w/ 32" tires. The last is the same lift, but w/ TJ rear flares, trimmed rear wheel well, and flat fenders and the same 32" tires.
