How much to lengthen a driveshaft? - JeepForum.com
post #1 of 9 Old 06-05-2011, 05:50 PM Thread Starter
ccbruin
Title says it all..
ccbruin is offline
post #2 of 9 Old 06-05-2011, 05:52 PM
alecmcmahon
For what?
alecmcmahon is offline
post #3 of 9 Old 06-05-2011, 05:53 PM
TheNewbie
Originally Posted by ccbruin View Post
Title says it all..
Somehow I'm thinking it doesn't.
But I'll take a shot here... I say lengthen it 10" and see what happens.
1995 YJ 2.5 - 4Ē RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #4 of 9 Old 06-05-2011, 05:53 PM
srdart67
it varies depending on the shop on how much they charge shop around. I got one done a year ago for $65 but I am friends with the guy.
srdart67 is offline
post #5 of 9 Old 06-05-2011, 06:17 PM Thread Starter
ccbruin
o sorry guys i meant how much money! my bad. Trying to weight the difference in cost of just lengthening it and keeping the t-case drop or getting a SYE/CV and getting rid of the drop. Money is major problem...
ccbruin is offline
post #6 of 9 Old 06-05-2011, 06:43 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I believe that entire driveshaft setup needs to be retired. You need a SYE and a cv driveshaft at this point. Are you planning an 8.8 swap in the future? If not, you just wasted time welding the perches on the 35 because you're not even close to where you need to be with your pinion angle. I don't mean to sound harsh, but SOA is dependent on having the funds to do it correctly. Now, unhook that beast and find yourself a SYE kit to ensure you don't lose all your ATF and drive it on the front axle while you save up to cut down a Cherokee shaft for what I hope is your 8.8 swap in the near future.
Anticanman is offline
post #7 of 9 Old 06-05-2011, 07:29 PM Thread Starter
ccbruin
It is a super 35 btw, but I do plan on going dana 60s in the future
ccbruin is offline
post #8 of 9 Old 06-05-2011, 07:47 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I wasn't as concerned with the strength of the axle or size of tire, that's a completely different issue. I was just looking at the housing you have now and where the pinion angle was. I run 35's on my Dana 35 so I obviously have no room to be telling people what axle to run, I just didn't want to see anyone have to reweld perches just to set the pinion angle because of the driveshaft change.
post #9 of 9 Old 06-05-2011, 08:11 PM
JeepinSC87
1987 YJ Wrangler
X2 on just saving your money and doing sye with cv driveshafts....especially since you seem to be aware of the weakness of the d35 and want to eventually go with a dana 60. Tom woods does a great job with driveshafts and also sells an sye kit. It's worth it...especially considering the piece of mind you get knowing you have a reliable setup!
'87 White YJ 4" RE suspension lift 2" performance accessories body lift Tom Woods CV driveshafts and SYE AX15 conversion 8.8 rear axle with l/s Dana 30 front axle with Powertrax No-Slip Traction System 35x12.50 Mastercraft C/T's WeBeR CaRbUeRaToR! KC Lighting
Doesn't it sound sexy?
JeepinSC87 is offline
DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ Joe Dillard YJ Wrangler Technical Forum 43 08-12-2014 07:53 PM
Questions about shortening a Cherokee front driveshaft to make a rear CV driveshaft AnonymousD YJ Wrangler Technical Forum 19 04-19-2011 09:10 PM
DS Lengthen...? jepmn03 TJ Wrangler Technical Forum 6 04-05-2010 08:12 AM
Ordered 3.25 RC Lift, will I have to lengthen my Brake Lines? townsman98 TJ Wrangler Technical Forum 7 03-17-2010 09:54 PM
SYE kit vs lengthen drive shaft -Q- TJ Wrangler Technical Forum 7 07-30-2003 11:03 AM
