how much labor to replace a brake line? - JeepForum.com
post #1 of 35 Old 04-28-2013, 09:36 AM Thread Starter
cgseanp
I recently took my 95 yj to a local shop to have a leaking brake line replaced. It was the line that ran to the back right tire. How long should that take? I even supplied the premade line. They are telling me 10 hours.. thanks
cgseanp is offline
post #2 of 35 Old 04-28-2013, 09:42 AM
4.7stroker
Find a different shop. With that quote they are telling you they don't want the work.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 35 Old 04-28-2013, 09:43 AM Thread Starter
cgseanp
Sorry. They did the work and then told me.10 hours. Am i screwed?
cgseanp is offline
post #4 of 35 Old 04-28-2013, 09:49 AM
BigYellow04
Dwayne
X2 it def should not take 10 hours to replace that
BigYellow04 is offline
post #5 of 35 Old 04-28-2013, 09:54 AM
4.7stroker
I hope they kissed you first.
Dwayne
[url]
[url]
post #6 of 35 Old 04-28-2013, 09:57 AM
dancytron
Are they telling you it is 10 hours out of "the book" or that it took them 10 hours? If they are saying it is out of the book, make them show it to you.
If they are saying that it took 10 hours, then ask them if they broke the connection trying to get it off.
When dealing with mechanics, always find out how they are going to charge you. If it is going to be "out of the book" (which it almost always is with good shops), then they should not have a problem showing it to you before hand.
dancytron is offline
post #7 of 35 Old 04-28-2013, 09:57 AM Thread Starter
cgseanp
Ya. So anyway to dispute something like this?
cgseanp is offline
post #8 of 35 Old 04-28-2013, 10:00 AM
gunshw301
That's just not right.
If they where to mine the minerals, smelt, do magic metallurgy stuff, form the steel tube, bend the lines, add the fittings, flair the ends, remove the old line, install the new line, bleed, test drive......then maybe ten hours would seem reasonable.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #9 of 35 Old 04-28-2013, 10:01 AM Thread Starter
cgseanp
Saying it took.10 hours. On the phone he was saying how he had to pull a bunch of stuff apart to get the brake line in and what not..
cgseanp is offline
post #10 of 35 Old 04-28-2013, 10:02 AM
gunshw301
How much did it cost? If its way out of hand then I would dispute. If not, then cut your losses and find a different shop.
post #11 of 35 Old 04-28-2013, 10:07 AM Thread Starter
cgseanp
500.. luckily only 50 an hour
cgseanp is offline
post #12 of 35 Old 04-28-2013, 10:07 AM
tom_sprecher
Dwayne
Dinner and a movie too.
Tom
tom_sprecher is offline
post #13 of 35 Old 04-28-2013, 10:09 AM
dillonjm
2013 WK
Wow.
For a brake line.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #14 of 35 Old 04-28-2013, 10:18 AM
gunshw301
I would just cut my losses and find a new shop. It's high, but not worth worrying about in my opinion. Just enjoy the jeep now that its working.
post #15 of 35 Old 04-28-2013, 10:19 AM
Ken3783
I would make them brake it down for what they had to "pull off" to get the job done because it shouldn't have taken anywhere near 10 hrs or had to take much off to fix it. That seems sketchy at best and would never use that shop again.......
'95 Wrangler YJ:
'98 Cherokee XJ:
'07 Grand Cherokee WK ("No Mods"-The Wife)
Ken3783 is offline
