How much Coolant? - JeepForum.com
post #1 of 5 Old 11-29-2011, 03:00 PM Thread Starter
baritone_mike
How much Coolant?
I just want to make sure 9 quarts is right. 1988 2.5L with OME radiator.
http://www.allpar.com/mopar/amc-25.html (it is at the bottom of the page under the chart)
So that is 4.5 quarts of anttfreeze and 4.5 quarts of distilled water right?
Also what should you do with coolant when you drain it? Can you take it to an auto parts store, or do you have to take it to the dump as hazardous waste.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #2 of 5 Old 11-29-2011, 03:39 PM
Spuznick242
Sounds about right. Usually I just fill it up to the top, run out the bubbles and air, then fill to the top again. Repeat if needed.
And some auto parts stores (most) will take it and dispose of it correctly, if not, go outside in a complete rage and dump it all over their parking lot (making sure to splash it on the windows, front door, and personal vehicles). Hahaha. No, dont really do that, just make sure it gets taken care of, if you cant find a place, check the phone book, their a bunch in there.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #3 of 5 Old 11-29-2011, 05:19 PM Thread Starter
baritone_mike
Okay, I just wanted to make sure so when I pull the lower hose I don't have a 9 quart bucket under it and have more then that in the radiator and on my garage floor. My radiator has a leak and is heavily corroded inside, but still cools well, so I am going to take it out and have it rodded out and get the leak fixed.
post #4 of 5 Old 11-29-2011, 05:32 PM
Spuznick242
Sounds like a plan. You might want to look at just getting a new radiator though. Thats the route that I took as well as most people. I paid $75 for mine and it was brand new aluminum, and for that I get a piece of mind as well.
post #5 of 5 Old 11-29-2011, 07:46 PM Thread Starter
baritone_mike
Where did you find a $75 radiator? The cheapest one I could find is $140 and that was copper like the stock one. I took it to a radiator shop and they said it is definatly repairable, because it is all metal. They said $75 to repair the leak and rod it out making it like a new one. It is a very small leak in the top right corner of the radiator.
Sweet Coolant Smell but No Coolant Leak? JB73 TJ Wrangler Technical Forum 4 11-07-2010 10:56 PM
I see coolant I smell Coolant But can't find leak. MrB TJ Wrangler Technical Forum 23 07-18-2010 06:33 PM
huge coolant leak/ creamy coolant?? 11Bgixx TJ Wrangler Technical Forum 17 01-11-2010 09:24 AM
Coolant looks like mud DaOne TJ Wrangler Technical Forum 8 09-05-2008 07:52 AM
Coolant Shane64 TJ Wrangler Technical Forum 6 11-12-2007 10:12 PM
