How much arch/bend in factory springs? - JeepForum.com
post #1 of 15 Old 01-23-2009, 08:23 PM Thread Starter
Burlbook48
Trial By Trail
Burlbook48's Avatar
I need to get new springs, the old factory springs that came with my SOA swap are shot (last weekend's fun run pushed them over the edge). For comparisons sake, what is the arch of new factory springs? Depending on how far mine have sagged, I may want to get 1" or even 2.5" lift springs. BDS and OME are likely candidates.
My heep is SOA, so my spring perch is on the bottom of the spring. For most of you running SUA, I figure a string pulled from shackle eye to shackle eye and measured to the spring perch, plus the thickness of the spring if SUA, would give me a ballpark of the springs arch.
Search didn't really give this info for factory springs, other than a single post stating "flat, or slightly bent". Anybody got a more specific number?
For what it's worth, I have a hardtop and about 220 LBS of rear bumper/spare tire hanging off the back, and the rear springs now have a negative arch of about 1/2". Add a couple passengers and gear, and the springs are just about hitting the bumpstops while parked. Yeah, they're toast.
You have to start somewhere to get to the middle of nowhere.
2015 YJ Of The Year
Thanks, but my rig is just a Prince among Kings. You folks gave me the answers to build it!
Burlbook48 is offline
post #2 of 15 Old 01-23-2009, 08:30 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I can't take measurements right at the moment because I'm at work, but I did an SOA conversion on my wife's '93 YJ and the stock springs were shot. I replaced them with the OE replacement springs from Q-tec for $79 each. They are stock height springs, and here's a pic of how they look.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 15 Old 01-23-2009, 08:40 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
The RE 1.5" SOA leafs measure as follows:
Since these are reverse eye wraped leafs (the eyes wrap from the tops, not from the bottoms) I put a broomstick handle across the tops of each end of the main leaf. Basically making a strait line between the tops of the main eye wrap. Both the fronts & rear leafs measure 2.75" of arch using this method.
Joe Dillard is offline
post #4 of 15 Old 01-23-2009, 08:50 PM
jgillespie
man i like your wife's jeep more each time i see it Max! i will swap with you, so you can have his N hers faded red '91 YJs
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #5 of 15 Old 01-23-2009, 08:53 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I think I'll keep the YJ. But can I talk you into taking the wife?
Mean Max is offline
post #6 of 15 Old 01-23-2009, 09:00 PM
jgillespie
aww come on man, im sure she ain't too shabby if she drives a YJ. my (soon to be) loves mine, and it's definitely a blessing!
post #7 of 15 Old 01-23-2009, 09:01 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yeah, I'm kidding. She's a keeper.
Mean Max is offline
post #8 of 15 Old 01-23-2009, 09:36 PM Thread Starter
Burlbook48
Trial By Trail
Burlbook48's Avatar
Looking at your pic, Max, your 1.5" shackles and 1" BL add a lot to your YJ's overall height. But, your 2.5" springs used SOA give a good bit of lift on their own compared to my wasted set. For example, the top of my 33's are higher than the top of the frame rail where it arches over the axle (using factory height shackles). Your frame rides, uhmm, significantly higher than mine.
2015 YJ Of The Year
post #9 of 15 Old 01-23-2009, 09:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Those are stock height springs, brand new. It's my wife's YJ, so pay no mind to my Jeep profile specs. The shackles on hers are 1" shackles. And yes, hers has a 1" BL too.
Mean Max is offline
post #10 of 15 Old 01-23-2009, 09:42 PM Thread Starter
Burlbook48
Trial By Trail
Burlbook48's Avatar
Thanks Joe, that's the kind of info I'm looking for. Just to clarify, you are measuring the springs while they are bearing the jeep's weight, and measuring to the top of the spring pack, right? I'd have to add about an inch to account for the 4-leaf spring pack's thickness when comparing to my height right now, I'm guessing.
2015 YJ Of The Year
post #11 of 15 Old 01-23-2009, 09:43 PM Thread Starter
Burlbook48
Trial By Trail
Burlbook48's Avatar
Okay, got it. Thanks Max!
2015 YJ Of The Year
post #12 of 15 Old 01-23-2009, 09:44 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Like I was saying, those OE height springs are only $79 each at Q-tec, and I've had no problems with them sagging or anything. It rides much better than my 2.5" SUA lifted '91 YJ does.
Mean Max is offline
post #13 of 15 Old 01-23-2009, 10:55 PM
Joe Dillard
Yep, exactly.
post #14 of 15 Old 01-24-2009, 07:23 AM Thread Starter
Burlbook48
Trial By Trail
Burlbook48's Avatar
Thanks for the clarification, Joe!
2015 YJ Of The Year
post #15 of 15 Old 01-26-2009, 09:27 AM Thread Starter
Burlbook48
Trial By Trail
Burlbook48's Avatar
Bump for the weekday crew. Hoping to get measurements of factory springs to compare on paper with Joe's RE 1.5" SOA spring measurements.
2015 YJ Of The Year
Can one re-arch leaf springs? Sambox YJ Wrangler Technical Forum 6 11-17-2009 10:16 AM
Are these factory height coil springs??? linexrandy TJ Wrangler Technical Forum 10 07-15-2008 05:08 PM
does factory use different springs for hardtop TJs? SpaComponents TJ Wrangler Technical Forum 19 10-18-2007 04:29 PM
replacing factory coil springs Jibbyjeep00 TJ Wrangler Technical Forum 12 12-07-2005 07:39 PM
help removing factory springs capeless YJ Wrangler Technical Forum 4 12-02-2005 10:29 PM
