Quantcast How much is a 90 YJ worth? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How much is a 90 YJ worth?
Old 04-01-2005, 08:10 PM   #1
87warrior
I have not spent much time over here on the YJ forum, but it seems the YJ's time here is expiring. We are looking at adding an XJ to the family and need to get rid of a set of wheels. Here is what I have:
1990 YJ
~120,000 miles
~4.2L (nuttered w/ carter still) Leaks a little oil, burns just a tad (synthetic oil too) (runs strong for an old 4.2, it does a signifigant cylinder wall wear on #1)
~Rebuilt AX-15 @ about 100,000miles (5th gear mesh cracked) Shifts smooth
~Has a very sticky clutch (is new with slave) I think the master cylinder needs replaced
~Rust in one spot, behind the passanger side fender flare (starting to bubble)
~Has a skyjacker 2.5 lift (springs are rusted) with the hydro shocks (no t-case drop) It does have sligh vibes at take off, could be cause by a warn Slip-yoke.
~Oil pressure gage does not work
~31" BFG AT's on AR wheels
~Besttop seats installed at about 100,000
~Soft top hardware only works if duct taped together
~Upper soft doors need replaced (zippers are shot)
And a few photos of it..... the annoying "Its a jeep thing" banner is GONE!!!!
This YJ also has a Salvaged Title. It was rebuilt in 1993 with front end damge. This is also when we purchased it. Also gets about 10mpg on average.
Whats the verdict guys? Is it even worth selling, or should we just keep it? Thanks in advance.
03 Rubicon(Rubicon build)
92 Comanche (92/99 Comanche Project)
87warrior is offline   Reply With Quote
Old 04-01-2005, 09:16 PM   #2
paultyler
Uncle Paul has spoken...
paultyler's Avatar
Try www.kbb.com
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote
Old 04-01-2005, 10:50 PM   #3
87warrior
I have been playiing around with numbers today:
KBB says its worth $2,850 (in fair, however it is more poor)
NADA is reading these three: $3,450 $4,500 $5,350
Edmunds.com says this: $755 $1,021 $1,489
This is the reason I posted this question.... $750-$5,350 is a BIG differance
I have searched a few sites (such as e-bay) for a comparable rig. None are close to what I have. I am also not sure how much the "salvage" title would effect this rig since it was repaired over 10 years ago.
What would you pay?
Old 04-01-2005, 11:07 PM   #4
boomhower
my advice for the oil problem, don't put synthetic in it. try a synthetic blend/higher mileage oil for good performance/better results. i know a guy that used nothing but proline for 150,000 miles, and had no problems. then he tried synthetic and it was oozing out of everywheres.
--1991 JEEP YJ 2.5l-- (trail beater)
RE 4". AA SYE. TW driveshaft. 33" TSL's. Snorkel. Olympic Rear Bumper. Warn XD9000i. Optima Yellow Top. Herculined Interior, Grill, and Rockers. TJ Flares. Cobra 19DX CB. Firestik antenna.
boomhower is offline   Reply With Quote
Old 04-01-2005, 11:39 PM   #5
87warrior
Boom- That is a good suggestion, however it just leaks a little out of the rear main. heck even my Rubi is doing that After dealing with the valve cover gasket for many years, I finally got it to seal using a 4.0 gasket. I also run synthetic oil to clean out the engine. The valves used to have a nice coating of goo on them, last time i changed the gasket they were coated in normal oil.
Old 04-02-2005, 05:46 AM   #6
pyro9862
Depends on how long you want to wait. Their is probably someone out there to give you $3500 for it, you have have to look long and hard to find him.
I'm going to look at a jeep later today 1989, 63,xxx miles, 6cyl, 5spd, hard top, 1in body lift, needs tires and drivers floor. Other than that it's in "good" (according to seller) shape although i've yet to drive it. He wants $2900 for it and i'm going to try and chew him down to $ 2500ish.
You might be doing yourself a favor to fix the master and gauge as well. That's the kind of thing a lot of people will look at and walk away. I got about $1000 less for my Grand Cherokee then it was worth because it had a bad cat, most people heard that and said no thanks even though I was taking that much off for a $300 job. The clutch master cannot be too expensive and the guage is probably a $25 sending unit.
The thing that I think might really hurt you though is that salvage title, that's another one that will turn a alot of people away on sight.
pyro9862 is offline   Reply With Quote
Old 04-02-2005, 07:33 AM   #7
Upstate Chili
Still a good looking rig, most of the defects on your list would be consider acceptable for the age of the Jeep. Same goes for the salvage title. That being said i think at $3500 it would sell in a short amount of time.
Upstate Chili is offline   Reply With Quote
Old 04-02-2005, 08:16 PM   #8
87warrior
The YJ is also "nuttered". Will it be hard to convince a person that it was the best thing to do? I have also reworked the harness in order to get rid of all the extra plugs. There is no way a person could "bring it back to stock". Under the hood it looks so clean.
My biggest question is this: How do you part with a Jeep you have owned for over 10 years and spent many painful hours workin on it? I really do not want to let go of it locally, I would hate to see somebody abusing it, ahhhhh
Old 04-02-2005, 08:26 PM   #9
Macabre
1990 XJ Cherokee
Originally Posted by 87warrior
My biggest question is this: How do you part with a Jeep you have owned for over 10 years and spent many painful hours workin on it? I really do not want to let go of it locally, I would have to see somebody abusing it, ahhhhh
Well, unless you really need the money or room I'd just keep it. I've only had mine for 13 months, and I couldn't imagine letting it go. Let alone 10 years. You've got your new rig to drive daily, so I'd make the YJ the project. Set it up as a trail rig, or restore it.
HRJA.org
PGH-OFFROAD.com
1990 XJ, 2-door, 4.0, AW4, NP231, 3" lift, 32x11.5 Interco SSR's. 104,000 miles.
Macabre is offline   Reply With Quote
Old 04-02-2005, 11:15 PM   #10
87warrior
Money is not much of an issue, but I am wanting to dump 2,500 in to the Rubi's lift and tires We are slowly running out of room here, and the driveway is turning into a dealers lot. Sure it would be a good project Jeep, but it still runs good and is a pretty poor base (D30/35).
I also failed to metion these defects (recalled them when driving today)
~Broken defrost cable
~Broken vent cable
~Very hard starting
~Warn out fron Tie-Rod ends
~Warn out Ball joints
The list keeps getting longer, maybe i am just trying to convince myself that nobody would pay high dollar for this rig. On the other hand, maybe its time to not be so selfish and let another poor soul see the "light" in the world of Jeeps
Old 04-03-2005, 12:09 AM   #11
bcshepard
I say dump the rubi and build up the YJ..
bcshepard is offline   Reply With Quote
Old 04-03-2005, 10:39 PM   #12
thumper242
So is it, or isn't it? If it isn't much of an issue, put it up for sale for how much you want to dump into the Rubi, and if it doesn't sell after a bit, drop by $500. It'll sell eventually.
When money isn't an issue for me, I take a good guess as to what it's worth, take off a bit, and sell it. That way I don't have to fiddle with selling something just to squeeze that extra bit out of it.
thumper242 is offline   Reply With Quote
Old 04-04-2005, 12:36 AM   #13
87warrior
When i state the money is not an issue, I am refering to an over all financial situation. That does NOT mean I am willing to let go of a Jeep I love for less than it is worth.
I am sure the the YJ would last another 100,000 miles with a few repairs. So I am not looking to "squeeze" anything out of it.
Thanks agian guys. If I am willing to drive 500 miles for delivery (customer pays for gas) do you think it will sell easier?
Old 04-04-2005, 01:12 AM   #14
ZonaWrangler
It has a salvage title? That's gonna make a big difference.
95 Wrangler Rio Grande. Herculined, AEM Brute Force, Helix TBS. No lift, Viper alarm, Primax rims and 30 x 9.5 Dunlop ATs. Gabriel HD shocks. My DD. Mostly ..... mostly.
ZonaWrangler is offline   Reply With Quote
Old 04-04-2005, 07:29 PM   #15
87warrior
Yes, as stated above it was repaired in 1993. No problems with what was damaged It was frontal body damage. I remember looking at it when the guy picked it up wrecked. It was wrecked in Texas after it was stolen from the oridginal owner. Looks like she took the insurance money
Glock Forum
