How many pounds can I pull and not break anything - JeepForum.com
post #1 of 14 Old 06-02-2010, 01:41 PM Thread Starter
pasinbuy
I tried a search b4 this post. I have a few trucks that weigh about 10,000 lbs empty. I usually park them on hard sand, although the sand here is getting a little soft where I have to park them and I was wondering if I used my Yj to pull one to harder ground to go out on a job if I may break something. I am talkng about pulling the 10k pound truck mayby 30 feet to harder ground.
Also should I use 4L or 4H. I was thinking 4L.
pasinbuy is offline
post #2 of 14 Old 06-02-2010, 01:52 PM
Louie4
"You pass butter"
Louie4's Avatar
I don't think it will be a problem for 30 feet. 4 LO is a must.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 14 Old 06-02-2010, 02:03 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Whatever you do - don't try to pull them while going in reverse in 4wd in your Jeep if they are somewhat stuck.
Your HPD30 ring gear may not do so well since you could overstress it while going in reverse under heavy load.
Joe Dillard is online now
post #4 of 14 Old 06-02-2010, 02:27 PM Thread Starter
pasinbuy
Thank Joe,
I have my trucks backed in just in case I have to pull them out. Since I may need to take one out at night I will be alone. I know better to spin my tires on the truck if I get stuck.
So you think that I will not have a problem and will not break anything if I pull a 10k pound truck out in 4L?
pasinbuy is offline
post #5 of 14 Old 06-02-2010, 02:35 PM
Joe Dillard
If it's not stuck, and your not going to be pulling it down hill with nobody in it you'll probably be okay going forward.
Being they are on packed sand, it's going to be touchy not to dig yourself in while trying to get them going. I'd probably try it if the circumstances were right.
post #6 of 14 Old 06-02-2010, 02:40 PM Thread Starter
pasinbuy
Ok, Yes if my tires start to spin on my Yj I will have to get someone in the truck to assist me while the truck is in gear. Problem is finding someone at night.
Thanks
Martin
pasinbuy is offline
post #7 of 14 Old 06-02-2010, 02:45 PM
Joe Dillard
You could try hitting up the local bar & offer somebody a free drink if they'd assist ya'. j/k
Is the location kind of out in the sticks?
post #8 of 14 Old 06-02-2010, 02:47 PM
ziebartrob
FWIW, I pulled an old (60 something I think) Jeep Gladiator that was hooked up to a 12' trailer loaded with a 1950's Ford tractor a couple of weeks back. I was in 4LO running about 2500-3000 rpm's going maybe 5-10 mph. I pulled him for 2 miles (approx) 'til we got to a dwnhill slope in the road and he could get his beast running again (he said it had a bad sending unit??). I have no idea the total weight, but I just took it easy and slow using only my tow strap. I was pretty proud of the old girl. Wife said I sounded like I was bragging about one of my kids after a good ball game If it matters she's a 4.0 w/ 5 spd. It did not seem to cause any damage (so far)
Originally Posted by Mymmars
when your start to anthropomorphise your jeep into somthing above a dog and below a hooker
ziebartrob is offline
post #9 of 14 Old 06-02-2010, 02:48 PM
bgredjeep
1987 YJ Wrangler
So are you pulling them (rather than just driving the trucks under their own power) for any particular reason? Are the trucks stuck, or are you asking just in case? If they are stuck in sand and you think the YJ will pull them out I think you are dreaming. At the very least you would need someone in the truck to help assist and man the brakes in case you actually do get it to move.
Also, none of this gets into how you are actually going to hook up to the truck to pull it. If the tube bumpers listed in your profile is correct you will need to search for a better place to strap to.
bgredjeep is offline
post #10 of 14 Old 06-02-2010, 03:36 PM Thread Starter
pasinbuy
My plan was to hook up to my ball hitch.
pasinbuy is offline
post #11 of 14 Old 06-02-2010, 03:48 PM
bgredjeep
1987 YJ Wrangler
Thats a negative ghost rider. I'm 1000% sure your receiver hitch is not rated for pulling 10000 lbs of stuck truck anywhere. Your entire bumper (and possibly your rear frame crossmember) will probably not stay attached to the Jeep.
post #12 of 14 Old 06-02-2010, 04:38 PM
ziebartrob
Dont rely on the hitch on your Wrangler for that. It will def exceed the tow rating for it.
post #13 of 14 Old 06-02-2010, 06:04 PM Thread Starter
pasinbuy
Ohhh, I see.
I do not want to pull the crossmember out as you mention. I know that my ball is only rated at 2k or so. I am not towing, only pulling. I know that the hitch receiver is pretty thick steel and should handle the load. Or am I wrong? My original concern was for my tranny and other drive line parts.
I never thought about the crossmamber What can I do to my crossmember to increase its' strength?
Others with a hook attached to the crossmember are they better rated?
pasinbuy is offline
post #14 of 14 Old 06-02-2010, 06:07 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
Baaagh... Pull away. As long as the truck being pulled isnt stuck.
I have pulled on motor homes with trailers attached and a jeep riding on the trailer. Pulled those piles of **** all over the lake bed.
What's the worst that could happen?
Edit-
Does the truck you are pulling run and have power to the wheels?
If so.... I wouldn't think twice about hooking up to it.
Even if it inst running, I'd pull on it, but i guess that is just me.
At KOH last year i was trying to no avail to snatch a full size flat bed truck from the sand. I was yanking the HELL out of that thing. Didn't get it out, but it wasn't for lack of trying
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
How Many Pounds Torque for Lug Nuts? PSYCH0 JK Wrangler Technical Forum 41 08-20-2010 12:11 PM
how many pounds is a tj tub? magnum629 TJ Wrangler Technical Forum 1 02-26-2008 02:04 PM
Inch pounds for body mounts Benderff TJ Wrangler Technical Forum 6 05-04-2007 10:31 PM
Inch Pounds to Foot Pounds... azcoyote TJ Wrangler Technical Forum 4 01-27-2007 04:04 PM
11 guage steel @ 65 pounds tough or not? CoreyTravis TJ Wrangler Technical Forum 9 12-12-2004 07:05 PM
