How to make Jeep Wrangler Run on Vegetable oil? - JeepForum.com
post #1 of 8 Old 04-17-2010, 01:33 PM Thread Starter
fallenbirdbeak
I'm really interested in doing this. I have seen others with lifted vehicles, Jeeps included, running on vegetable oil. I have even seen some old Mercedez-Benz cars with stickers claiming they run on vegetable oil.
So, does anyone have an idea as to how to begin this modification? Gas sucks!
My Jeep doesn't get me laid, but who cares.
My goal in life is to be able to work on cars like Tony Starks from Iron Man.
fallenbirdbeak is offline
post #2 of 8 Old 04-17-2010, 01:40 PM
OOXTEME
do the 4bt swap? or the mercedez diesel swap?
OOXTEME is offline
post #3 of 8 Old 04-17-2010, 01:45 PM
MoparFreak69
Yeah good luck on getting a gas engine to run on WVO (waste vegetable oil). You need a diesel engine for that. This involves a swap of some kind and do not expect it to be cheap. The money you spend probably wont be recovered on the fuel savings.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #4 of 8 Old 04-17-2010, 02:14 PM
jtpaintball70
jtpaintball70's Avatar
Gas engines won't run on oil. They will run on propane though
Nathan
KD5QHI
NREMT-I/85
jtpaintball70 is offline
post #5 of 8 Old 04-17-2010, 02:25 PM Thread Starter
fallenbirdbeak
Is propane cheaper than gas?
post #6 of 8 Old 04-17-2010, 02:28 PM
bigsquat
being that your in california, and an enhanced smog area i would check with your local smog laws b4 starting a diesel swap or propane setup. my buddy has a 4cyl diesel in his land cruizer and he loves it now he put a turbo on it. his is pre 1976 so anything goes. i wish they made cj7's b4 1976 ,i would have bought one and not delt with every 2 years and drop any motor you want in. pre 76 jeeps are just to small
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #7 of 8 Old 04-24-2010, 04:02 PM
xani
You need to do a diesel swap first, between 10-$18,000 usually. Then you do a greasecar conversion, basically, it just adds a new tank that heats the oil then you car runs off both diesel and vegetable oil. If your Wrangler is already a diesel then the grease upgrade is only about $1,000.
This certainly isn't an upgrade to save $$$$ when you take into account that it can cost $20,000. If your car is already diesel then it will save money, because you can get the oil for free from restaurants and recoup the costs for the grease upgrade in a few months and after that drive for free (except for starting/turning off the engine, which has to be done with diesel).
xani is offline
post #8 of 8 Old 04-24-2010, 04:53 PM
pasinbuy
I installed a propane setup in a truck I had many years ago. I could switch from propane to gas with the flick of a finger.
Propane gets about 10% less miles to the gallon, The good part about propane is that your oil never gets dirty. No carbon build up. Propane runs very clean.
pasinbuy is offline
Engine make of a 1991 Jeep Wrangler. Duffboy YJ Wrangler Technical Forum 6 07-11-2008 04:10 PM
What can I make for my 02 wrangler? case'sjeep TJ Wrangler Technical Forum 10 02-03-2008 08:24 PM
Wrangler Unlimited might make me a Jeep Owner! - Merged Threads Martinjmpr JK Wrangler Technical Forum 22 11-08-2006 08:07 PM
Why Did Jeep not make a Wrangler in 1996? 01JeepXJ TJ Wrangler Technical Forum 22 04-14-2006 06:59 PM
does anyone make this for the wrangler TJ? Tobey TJ Wrangler Technical Forum 12 05-24-2005 08:47 PM
