How to.. make a big hole in your jeep... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How to.. make a big hole in your jeep...
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 06-14-2010, 08:51 AM   #1
giggityjeeper
Seat belt Rust repair/Frame Repair/SOA
..start by finding a small rust hole you want to fix....
said hole...
I want to fix it cause Im having the same issue another guy posted, flexing the panel to much and the seat belt is falling out now so.....ya......prolly time ot take a look at it....
so before you do this make sure you take a GOOD look ...upon closer inspectin my body mount is cracked and falling thru the flor as well, and hte seat mount it cracked bad, this I already knew...the body mount I did NOT.
SO first off
seat mount...
so I pull the rock guards off and WOOHOO another small hole...
off to the right...
off I go cutting.... to add more to the story this side of the Jeep was smakced a few years back before me, so it is about 1/4 iof bondo on the whole side...this I knew to as I painted it before, but the previous damage is taking it tole now, I just need to snuff it up so I can put my new fenders on, what started all this was the family roll bar swap, I took the bar out and figured WTH might was well do this at the same time...
anyway here it is now, this will take some time as I dont have alot of free tiem this week, and need someone to do the welding for me, I R Not a welder...
The tuff part will be replacing hte C channel for the body mount and getting the side to line up, I have to make a piece on the insdie as well were hte seat belt mounts, the little part that sticks out, really dumb design when you cut into it actually.....
any idears from ppl who did this...
Started with some rust repairs ended in a SOA...
http://www.jeepforum.com/forum/f12/h...-jeep-1050879/
family roll bar swap/upgrade..
http://www.jeepforum.com/forum/f12/f...grade-1054753/
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline   Reply With Quote
Unread 06-14-2010, 08:54 AM   #2
ImpactFabWorks
Everytime I read one of these rust threads I love california that much more. I'm rust free and can remove any bolt at anytime with-out a week of PB prep
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
www.Impact-FabWorks.com
Impact-FabWorks Facebook
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline   Reply With Quote
Unread 06-14-2010, 09:21 AM   #3
MLJeeper
No kidding, im glad i live in the rust free South.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline   Reply With Quote
Unread 06-14-2010, 10:23 AM   #4
pasinbuy
I would never buy a car that came from the north. They salt the roads to get rid of the ice and snow. Plus the snow clings to your car for monthes and you cannot clean it because it then will have a sheet of ice covering it so. The result is that they or you ruin your car.
pasinbuy is offline   Reply With Quote
Unread 06-14-2010, 10:29 AM   #5
Contra
lol..me too, ...salt free south
Ever Gone Geocaching?
Opencaching
Contra is offline   Reply With Quote
Unread 06-14-2010, 10:31 AM   #6
sparkeep
I am reading this and thinking forward 5+ years when (not if) rust takes a good hold on my Jeep. It will not be as easy for me to cut out and replace panels because it lined the inside with Line-X. I guess I'll cross that bridge in 2015 if the earth still exists after 2012!
2005 Impact Orange Rubicon
6 speed standard 4.0L I6 engine
Mechanical Engineer behind the wheel
Toronto, ON, Canada
sparkeep is offline   Reply With Quote
Unread 06-14-2010, 11:23 AM   #7
DaleC
Amen Brian,
Just pulled my trac bars yesterday without PB or even a BFH. Very easy with no rust issues.
DaleC is offline   Reply With Quote
Unread 06-14-2010, 11:25 AM   #8
giggityjeeper
ok great we have established that in the north you get rust... like I said, the rust is due to previous damage on this side, the other side is perfect....
beside I will take my non smog carberated jeep and my free healthcare over your no salt....
moving on, anyone got some ideas or advice to make this all pretty again...
Unread 06-14-2010, 11:36 AM   #9
ImpactFabWorks
well its pretty straight foward. go buy sheet metal and start forming it. re-inforce the roll bar section then its time for some body work and paint
Unread 06-14-2010, 03:39 PM   #10
rcpd34
Boy, prolly be easier to just replace the tub. There are several around here for around $200.
Brian
rcpd34 is offline   Reply With Quote
Unread 06-14-2010, 04:16 PM   #11
awkrueger
Yea, I'm used to rust. Vehicle inspections? Smog tests? huh?
awkrueger is offline   Reply With Quote
Unread 06-14-2010, 05:16 PM   #12
rcpd34
Not to mention earthquakes, wildfires and mudslides...
Brian
Unread 06-14-2010, 05:54 PM   #13
st2joker
i live in fla and i dont have any of that
88 yj 350 chevy ba10 stock axles, 9" with a locker and a 44 front both with 4.10 gears waiting to go in. new stock springs 1.5 shackles tj flares, 33x12.5x15 coopers 15x8 rims
if you cant have fun, why bother
st2joker is offline   Reply With Quote
Unread 06-14-2010, 06:08 PM   #14
1992 renagade
Dude have you ever lived up north? Yes we get snow and they salt the roads but a few days later it get above freezing and you wash your car and I normally presure wash underneath the Jeep it's realy not that big of a deal.
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications www.atozfabrication.com
Blue Mountain Jeep Alliance www.bmja.org
Delaware jeep Association www.delawareja.com
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline   Reply With Quote
Unread 06-14-2010, 07:10 PM   #15
plym49
Originally Posted by giggityjeeper View Post
beside I will take my ..... free healthcare over your no salt....
Free health care? What's your tax burden again?
plym49 is offline   Reply With Quote
