Quantcast How to lower windshield??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How to lower windshield???
Old 10-23-2009, 09:22 AM   #1
doughnutdog
Hey y'all....
I am trying to lower windshield, so I can get to wiper motor. I have removed holddown straps on the interior (next to both doors) and unbolted roll bar from the frame, undid wipers, but yet, the windshield will not drop??? What am I missing???
doughnutdog is offline   Reply With Quote
Old 10-23-2009, 09:29 AM   #2
muddy93
1987 FSJ Wagoneer
first, fill out your profile, so that we know what jeep you have.
second, assuming that it's an older YJ, the hinges are probably seized, you can try soaking them in some pb-blaster, or other penetrating oil to try to free them up.
just be sure to use caution when folding it down, if you have to force it at all, there is a chance that you could bend the hinges, and end up needing new ones.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline   Reply With Quote
Old 10-23-2009, 09:30 AM   #3
ExNeph
Check your windshield hinges and make sure they're not rusted or clamped shut? Other than that, the two straps and rollbar torx should be it.
Jeep owned for over 1 year.
Parts broken/blown up: Engine, clutch, transmission synchros, wheel joint, wheel bearing, front driveshaft u-joints, front shaft oil seal, radiator, water pump, belt, passenger door latch, cat-back exhaust system, front fender flares, front axle seal, transfer case output seal, rear driveshaft u-joints, parking brake..
ExNeph is offline   Reply With Quote
Old 10-23-2009, 09:30 AM   #4
Baerr
Check to make sure the roll bar mounting plate is not wedged between the windshield frame and the sunvisor mounts... I've done this before, tried to force down the windshield and stripped the sunvisor mounting bolts right out of the windshield frame...
Might seem silly, but check...
Baerr is offline   Reply With Quote
Old 10-23-2009, 09:33 AM   #5
ExNeph
I can't believe I forgot that. Hahaha, I had the same problem when I put mine down. Felt like such a putz.
Old 10-23-2009, 09:34 AM   #6
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
This was exactly what i was going to suggest. I have done that many times.
If that isn't it, then your hinges are probably seized. Try and soak in some PB blaster but you may end up replacing the hinges.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 10-23-2009, 09:35 AM   #7
Louie4
Injanir
Louie4's Avatar
If you took the sun visors off, unbolted the plates on each side next to the dash and unbolted the roll bar supports, I say push harder.
And yes, I have made the mistake of not unbolting the sun visors.
Lou
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
Old 10-23-2009, 09:38 AM   #8
rustywrangler
Be careful with this advise though. This is the exact reason I needed to replace my hinges. I pushed too hard on seized up hinges and they just folded over, not via the hinge but the metal just below it..
Old 10-23-2009, 11:03 AM   #9
china-clipper
As previously stated many times....be real careful when attempting to fold down the windshield. Watch the hinges (and have a buddy watch the other one) and watch for "flexing" of the frame and cowl mount as opposed to hinge movement. Bending a hinge may seem like an easy fix until you realize those torx fasteners are NEVER going to come out. That means drilling, tapping, etc. Or even worse, the torx just spins and doesn't come out.
china-clipper is offline   Reply With Quote
Old 10-23-2009, 12:00 PM   #10
Poke
Poke's Avatar
I bent my hinges and its suked. be easy and WD-40/PB blast the hinges as much as possible
mild mechanic that's overly ambitious
Jeep Envy
Originally Posted by Hashbrown View Post
The trouble with running is...by the time you realize you're not in shape for it, it's too far to walk back.
Complete YJ Besttop with hardware for sale. PM me.
Poke is offline   Reply With Quote
Old 10-23-2009, 12:13 PM   #11
Louie4
Injanir
Louie4's Avatar
Good point Rusty. I should of thought of that. Luckily my hinges aren't rusty. Mine stuck a little bit when I first tried to push it down. I gave it a few more "nudges" that were a little harder and found that someone had put some RTV in between the cowl seal and body, plus the paint on the hinges might have held it a little too. On a side note, I drilled two 1/8" dia. holes on each side of the windshield frame to drain water. When I first drilled it, water came out in a steady stream, just in case someone has a similar problem.
Lou
Old 10-23-2009, 12:21 PM   #12
Mitchness
Got any pics of where you drilled these holes?
Mitchness is offline   Reply With Quote
Old 10-23-2009, 12:36 PM   #13
Louie4
Injanir
Louie4's Avatar
I'll take some today after work and try to upload them. My bluetooth on the computer has been acting up but I'll make it work. (Blackberry camera phone at the moment).
Lou
Glock Forum
