How long does it take to change a serpentine belt? - JeepForum.com
post #1 of 12 Old 08-23-2005, 12:56 PM Thread Starter
JaySpencer66
So today I get a call from my wife who is driving our other vehicle, a Mazda Tribute. She said that she got out of the car with no issues, parked the car with no problems, got back in, turned the key and "nothing." So now she will have to drive the Jeep, which is okay but I would like to get the serpentine belt changed because it squeels quite a bit. I was wonderring if anyone can tell me how long it would take to do the serpentine belt on average? I planned on doing it on Saturday when I had all day anyhow, but I may want to do it tonight if it is a 2 hour job kind of thing. (It's a 91 with a 4.0 and no AC.)
I have air tools, and a 24" breaker bar as well as the belt already in hand.
Thanks in advance to anyone who even reads this, let alone can tell me.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Member #1 of the "I Hate Torx Club!"
~anyone with a Jeep is an automatic member, and anyone can be member #1~
JaySpencer66 is offline
post #2 of 12 Old 08-23-2005, 01:09 PM
bretm
Shouldn't take too long, maybe half and hour if the first time you're doing it (just to figure out which bolts you need to loosen to pivot, what size they are, walking back and forth to the tool box, etc.)?
The belt is probably just loose, but if you bought a new one already, put the new one on and keep the old one for emergencies (I keep one in a plastic bag stuffed in the engine compartment under the battery tray).
I'm not sure where the 4.0 pivots, my 4.2 w/AC is tensioned by the alternator.
Black '88YJ 4.2L
2.5" Skyjacker, 32x11.5s, 4.11s, Weber, HEI, etc.
bretm is offline
post #3 of 12 Old 08-23-2005, 01:10 PM
TellyDSP
Poland and PPV!!!!
I did my 95 2.5 in about 20 minutes, first timer. That includes figuring out how the hell to loosen the tensioner bolt(couldnt find it) and figuring out which of the two belts I got was the right one. Of course I picked the wrong length first. You just loosen the long bolt that goes behind the PS pump and it will move the tensioner pulley(assuming its the same on the 4.0). Then slide the belt off and put a new one on. I'd say 30 minutes tops, if you're truely lost. Did it again when I changed my thermostat and took only a couple minutes. Grab a Haynes for more detail.
edit: damn, beat me to it. Also, a standard socket set w/extension is all you need.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #4 of 12 Old 08-23-2005, 01:39 PM Thread Starter
JaySpencer66
Sweet! Thank you both! I happen to have the Chilton's already and briefed myself on the unbolting order already!
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
post #5 of 12 Old 08-23-2005, 02:09 PM
olyjeep
Good luck! Mine was a pain to get the tensioner to move.. rusted solid... Now I know about the modern marvel "PB blaster" which probably would have made it alot easier
2005 Khaki LJ Auto
2.5" Pro Comp Lift
32" BFG AT
olyjeep is offline
post #6 of 12 Old 08-23-2005, 02:12 PM
TellyDSP
Poland and PPV!!!!
My new best friend is the wire brush. Even if you get the nut un-stuck, if the threads are a mess, the jobs a b!tch. Since the wire brush, the rest is easy.
-Craig-
95 Rio Grande
07 Ram 1500
TellyDSP is offline
post #7 of 12 Old 08-23-2005, 10:03 PM
sjlplat
Screw that tensioner. It's easier to remove the alternator.
sjlplat is offline
post #8 of 12 Old 08-24-2005, 06:56 PM Thread Starter
JaySpencer66
It took about one hour to do! And man what a PITA!!! Because of the location of it, the fuel lines, and PS lines I was lucky on the back bolts, and side tensioner to get things moving more then 1/4 turn at a time!
I got it done with a little patience, and enjoyed the blissful sound of the truck starting very quickly with no squeel at all! (BOOO YAH!!!!)
I noticed that I have a cracked, what I assume to be a vacuum line that I posted in another thread. ~sigh~ At least it does not seem to be anything I was not expecting though, but boy did it look nasty.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
post #9 of 12 Old 08-25-2005, 08:09 AM
sjlplat
That's why it's easier to remove the alternator. Loosen 1 bolt, remove the other. Replace the belt, re-install the bolts, and you're done. 10 minutes.
sjlplat is offline
post #10 of 12 Old 08-26-2005, 10:44 AM Thread Starter
JaySpencer66
If I have to do that again I will truly consider it! The only thing I see with that is tensioning it.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
post #11 of 12 Old 08-27-2005, 08:13 AM
sjlplat
Nothing to it. Use the tensioner to give you enough slack to re-install the alternator, then adjust accordingly once it's all back together. Only requires a couple turns, rather than cranking on it for an hour.
sjlplat is offline
post #12 of 12 Old 08-27-2005, 09:09 AM Thread Starter
JaySpencer66
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Serpentine belt too long? tjsahara1979 TJ Wrangler Technical Forum 10 11-22-2009 01:25 PM
When to change serpentine belt? Thunderstrike TJ Wrangler Technical Forum 5 01-25-2008 11:21 PM
Serpentine Belt Change! Exhale YJ Wrangler Technical Forum 3 02-25-2007 09:11 AM
Serpentine Belt Change SpitNine TJ Wrangler Technical Forum 1 05-03-2006 03:21 PM
99 Jeep Wrangler Serpentine Belt Change: How To? Ken Gollinger TJ Wrangler Technical Forum 1 08-04-2005 02:24 PM
