How Long Can I Run With Bad Head Gasket? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How Long Can I Run With Bad Head Gasket?
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiPoison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 08-15-2012, 01:43 PM   #1
Matt The Hammer
I'm going through around 1/2 gallon of coolant a week, maybe more depending on how much I'm driving. Did the head gasket test on the radiator and it showed exhaust gas in the coolant.
So I need a new head gasket.
Low on wrenching time right now.
How long can I drive like this? Mind you, I only drive my YJ around 75 miles a week these days as it's a second car.
I have 203k miles on a 95 2.5 engine.
2013 JKU
1995 YJ
Matt The Hammer is offline   Reply With Quote
Unread 08-15-2012, 01:45 PM   #2
42YJ
The longer you run it the more damage your doing to your motor you are probably leaking coolant into the oil or vice versa and it can lead to very very bad consequences I would park it until you get it fixed if you plan on reusing that motor
42YJ is offline   Reply With Quote
Unread 08-15-2012, 01:47 PM   #3
bigbuk29
should have stopped driving it the day you did the test, you are only doing more damage now
bigbuk29 is offline   Reply With Quote
Unread 08-15-2012, 01:52 PM   #4
NonRubicon
Ditto. The moment you noticed your engine was eating coolant you should have stopped driving it.
If you continue to drive it with a bad head gasket you may very well end up warping the head, if you haven't already. My brother did this to two different cars.
NonRubicon is offline   Reply With Quote
Unread 08-15-2012, 01:58 PM   #5
Matt The Hammer
Thanks. Advice taken.
What was I thinking? ha ha
These responses will be relayed to my wife when she grumbles about me working in the garage this weekend.
2013 JKU
1995 YJ
Unread 08-15-2012, 02:28 PM   #6
dtn8tr
dtn8tr's Avatar
You can drive it until seizes if you want to! Probably not a good idea though.
1988 YJ, 4.2L, 2.5" OME, .75" boomerangs, 33x12.5x15 Cooper Discoverers, Herc'd,Nuttered, TeamRush'd
2001 WJ stock DD, 4.0l, Select-Trac
Most good stories start out "Y'all ain't gonna believe this ****...."
dtn8tr is offline   Reply With Quote
Unread 08-15-2012, 09:28 PM   #7
bigbuk29
I get the same grumbling from my girlfriend, it all stopped when she took her Lincoln Navi to the shop for a full tune up, oil change yadda yadda, and it cost her almost 800.00 and i showed her I could have done for less than half and a saturday in the garage, and still could have drover her to dinner in it that night
