how to install TJ uppers on 1/2 doors w/ hard top - Page 6 - JeepForum.com
 1Likes
post #76 of 96 Old 09-05-2012, 03:16 PM
Ripper3494
just ordered my set for around 200 bucks interested to see wether this works, both of them have returns on them so i should be good
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #77 of 96 Old 09-05-2012, 07:31 PM
glenn-91YJ
glenn-91YJ's Avatar
Well I got the Softopper installed. I used my hard doors to adjust the surrounds that came with the top. They sealed up really nicely. I haven't had time to mess with the Smittybilt uppers...I'm in the middle of roofing my house! It's a metal roof and is a little slower than asphalt!!!
Very happy with the the top.
Attachment 466728
The corners are a little loose but there's no way to tighten them up. Probably needs the track to wrap the corner.
Attachment 466729
Attachment 466730
Metal roof...REALLY NICE STUFF! It looks just like slate and has a Lifetime Warranty for the original owner...and it's transferable too.
Attachment 466731
Flashing the dormers is slow going. If it wasn't for this roofing project the Jeep would have had the axles swapped by now!
Attachment 466732
Owning a "Renegade" means being "Different"!
"The greatest danger to American freedom is a government that ignores the Constitution."
-Thomas Jefferson
glenn-91YJ is offline
post #78 of 96 Old 09-05-2012, 08:07 PM
jimmybob67
Waiting to see how this turns out. I have a Sunrider soft top and a standard hard top. My full doors fit both but no uppers for the half doors.
jimmybob67 is offline
post #79 of 96 Old 09-05-2012, 08:18 PM
Ripper3494
ill post up my mod of them on this thread if thats ok with the OP, that way more ppl can see how it works, or doesnt.
build thread:
RC vs BDS
post #80 of 96 Old 09-12-2012, 11:04 PM
Ripper3494
heres my write up
http://www.jeepforum.com/forum/f27/t...d-top-1416480/
build thread:
RC vs BDS
post #81 of 96 Old 10-10-2012, 10:03 PM
kodyowenby10
1987 YJ Wrangler
Do the tj upper have the channel for the bottom of the skin built into them? I have a 87 so mine originally had buttons to hold the bottom of the skin?
kodyowenby10 is offline
post #82 of 96 Old 10-11-2012, 07:37 AM Thread Starter
texas_yj
TJs have a flat metal bar accross the bottom if the upper and a seal built into the skin. You have to remove the belt From the lower door. In your case, you will have to remove the snaps if they are in the way. I haven't seen what you have before. Are the snaps on the flat main panel of the lower, or the beveled over top. See post 3 for a good set of pictures
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
post #83 of 96 Old 10-11-2012, 07:25 PM
kodyowenby10
1987 YJ Wrangler
I didnt put the snaps back on after i painted it so I should just be able to weld the tj uppers up slap them on and go
post #84 of 96 Old 10-12-2012, 06:45 PM
BuffaWrangler
For any of you that have done this... would it be viable to do with the rear pin cut off for a Winter? I may not have access to a welder for a while, and just picked up a hard top cheap. I'd love to run it with my half doors this Winter.
BuffaWrangler is offline
post #85 of 96 Old 12-21-2012, 12:35 AM
jmmorgan82
2009 JK Wrangler
I see all these posts are for people running the TJ uppers with a hardtop. Do any of you run them with a soft top? I'm looking for a set of uppers to work with my Supertop, and can't find anything YJ specific locally, but can find plenty of TJ uppers. Any of you guys have experience with this setup?
jmmorgan82 is offline
post #86 of 96 Old 12-21-2012, 09:13 AM
Eron
Does you soft top have round or square corners?
Eron is offline
post #87 of 96 Old 12-21-2012, 11:29 AM
jmmorgan82
2009 JK Wrangler
Round, it's a Supertop.
I know they'll fit dimensionally, I just wanted to know if anyone had actually run this setup to see how they seal against the Supertop frame.
post #88 of 96 Old 12-26-2012, 04:59 PM
jmmorgan82
2009 JK Wrangler
I finally got around to getting the TJ uppers I scored mounted. The short answer to my previous question is, they don't fit very well due to the Supertops frame design.
The following pic is from the drivers side rear of the window and you can see the gap it leaves:
I could probably tweak the frames, add some extra weatherstripping, etc, but at the end of the day, the fit is garbage. I'll be looking to either get actual YJ uppers or trading my Supertop for a hardtop.
post #89 of 96 Old 01-12-2013, 07:51 PM
jmmorgan82
2009 JK Wrangler
I got the uppers to fit snug on the Supertop today. I had to switch the vertical rod supports around so the uppers wouldn't hit them and would allow my doors to close all the way. After swapping them and "tweaking" the rods (pulled on them with all my might), the doors seal up nicely all the way around.
^The upper frame was hitting the flat part and not allowing the door to shut completely. After swapping them around, it shuts all the way.
Now I just need to cut/weld the rear pin so I can do final adjustments and put the door panels back on, then order some black skins.
Here's how it is currently installed:
Sorry to hijack/bump this again, but I figured this would be helpful info for someone in the future.
post #90 of 96 Old 03-07-2013, 04:52 PM
BuffaWrangler
I also got the TJ uppers to work with my half doors and hard top. I had to pull the spreader bar in to the minimum distance to slide the top rearward, but it works. Added some sticky weatherstripping, and I'm golden. Thanks for this thread guys!
How do you like your hard half doors and soft uppers? smitkev2 JK Wrangler Technical Forum 22 08-25-2009 09:06 PM
Will TJ soft uppers fit YJ hard half doors? JaikYJ Wrangler General Discussion 0 03-24-2009 09:53 AM
Hard doors or hard uppers Why J? YJ Wrangler Technical Forum 10 11-03-2005 05:35 PM
Need Uppers and half doors Satelliteguy YJ Wrangler Technical Forum 1 07-10-2005 09:02 PM
half doors(uppers) jeeper-creepers TJ Wrangler Technical Forum 1 06-21-2004 03:44 PM
