how to install TJ uppers on 1/2 doors w/ hard top
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |
Senior Redneck Member
write-up: how to install TJ uppers on 1/2 doors w/ hard top
I have seen allot of questions about fitting soft uppers on your YJ with a hard top. with full doors going for around $800 in some places, and tops for $5-800, using some ebay uppers and frames is very economical. I sourced my uppers&frames from this complany for $169.99 shipped, but they have gone up a little
pictures of the jeep with both sets of doors side by side The new skins and frames arrived unassembled and in good order, I put one together. You can see here how the last pin does not align properly, and needs to be cut and welded after cutting, make sure you protect your door while tacking it together!!!
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt. 2) 99 TJ 5.0 mustang GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT on MB Chaos 5s, superlift 6" RR long arm, D30/44 w/ ARBs & yukons, warn bumpers, custom sliders, Mile Marker winch - work in progress! Last edited by texas_yj; 01-10-2010 at 06:58 PM.. |
#2 |
Resident Audio Guru
Pretty straight forward modification, its great to see with the pictures you posted how easy it really is. This really opens up possibilities for us YJ guys that have, for the most part, been soft top or hard doors with no options.
-Matt White '94 YJ Sport Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar Project (s)Low - A build log. |
#3 |
I discovered that some doors may hit the fiberglass of the top, mine just nicked it, so I filed it to clean it up and repainted it
You will need to remove the YJ belt rail, the TJ doesn't use it and has a nice seal on the bottom instead I had to trim off the tail on the rear part of the seal, tapper cut it so that it seals to the door nicely. You will have to play with the pins alittle to get everything to align right, but one you get it right, it seals up nicely, Mine is as quite going down the road as my full doors, it has no leaks anywhere, and you cant see light from anywere around the door. I had to shorten the middle and last pin so they would sit lower on the door, and tweeked the front pin to hold it higher.
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt. 2) 99 TJ 5.0 mustang GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT on MB Chaos 5s, superlift 6" RR long arm, D30/44 w/ ARBs & yukons, warn bumpers, custom sliders, Mile Marker winch - work in progress! |
#4 |
This pic didn't make the writeup, but does a real good job of showing how well the frames fit the hard top so I'm throwing it out there
#5 |
Lunch Hour Runner
Very cool! Seeing the pic makes it clear exactly how the pin needs to be modified.
Looks good, too. Wonder if anybody makes white uppers to match my white hardtop? My Bestop soft uppers are spice to match my Supertop.
4.0, AX-15, 231 T-case with JB Convs. SS-SYE & Wide Chain Kit, D44's f&r, Detroit front, ARB rear, rear disc brakes; 5.13 gears, SOA on RE 1.5" SOA springs, 1-ton High Steer, anti-wrap bar, 33x12.50/15 Open Country MT's on 8" Ultra type 50's, 7" flares, BESRK rear bumper & tire carrier, Shrockworks Rocker Guards, PIAA 940 Dual Beam fog/driving lights, some other small stuff.... and still a work in progress |
#6 |
Dang, you beat me to it. Looks great, I just got my uppers last night.
01 TJ stock for now! OlllllllO |
#7 |
Got my eye on you.....
Added to the FAQ.
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#8 |
Thanks, I wish I could get the Cherokee moderators to do that once or twice in a decade....
#9 |
Resident Audio Guru
You might be able to adjust the spreader bars on the roll bar to pull the windshield back ever so slightly. This will move the hard top back as well and clear the doors properly.
#10 |
Go Kings Go!
Great write-up and excellent pictures.
I have seen the question a million times, and its always been one of those subjects where someone thinks it might work. Thanks for clearing it up with so much detail.
95 Black YJ *Build Thread* 2.5L, 4.5" RE springs, MORE hoops 1" BL, 35" KM2's, Tube Fenders, Full Cage, D30 Aussie, TeraLow 4:1, HF 8K Winch Herculiner, Warn steering & Gas Tank skids, LED tail lights, TJ corners, Rock Sliders, Ford 8.8, JCR OTK Steering |
#11 |
Does anyone have some pictures of how the YJ soft upper does (not) fit on the hardtop? I am having troubles seeing why it would not fit.
#12 |
Resident Audio Guru
There are no companies that make YJ soft uppers to fit hardtops. The only one that does is BesTop for their Supertop soft top, and the Supertop corners are a different radius and angle from the stock hard top. Why ? No idea.
#13 |
I guess I'll go see for myself.
The radius of the top corner must be very close, because looking at pictures there is not much difference. |
#14 |
[I'm That Good]
Wrong... There is a company. I purchased a set of them prior to giving in and buying my Bestop Hard uppers a few years back. The only problem is that they didn't fit as promised and the quality was nowhere near that of Bestop. Can't remember the brand anymore... I posted it several years back if you feel like searching my posts a bit.
Pimptiva.com |
#15 |
not much difference? LOL...TJ has ROUNDED corner, YJ is SQUARE....if you don't believe me you can check my classifieds and see the YJ ones im selling...you can use them with a hard top, but you will have to SLAM the door to get it to close, and it will overlap and look like ****.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
