-   -   how to install TJ uppers on 1/2 doors w/ hard top (http://www.jeepforum.com/forum/f12/how-install-tj-uppers-1-2-doors-w-hard-top-945300/)
texas_yj 01-10-2010 05:17 PM
write-up: how to install TJ uppers on 1/2 doors w/ hard top
I have seen allot of questions about fitting soft uppers on your YJ with a hard top. with full doors going for around $800 in some places, and tops for $5-800, using some ebay uppers and frames is very economical. I sourced my uppers&frames from this complany for $169.99 shipped, but they have gone up a little
http://rover.ebay.com/roverimp/1/711...mpt=126316990297-06 Jeep Wrangler BLACK Upper Doors Soft Top W FRAMES:eBay Motors (item 190361956336 end time Jan-10-10 17:35:59 PST)
pictures of the jeep with both sets of doors side by side
http://im1.shutterfly.com/media/47a0...D550/ry%3D400/http://im1.shutterfly.com/media/47a0...D550/ry%3D400/
The new skins and frames arrived unassembled and in good order, I put one together.
You can see here how the last pin does not align properly, and needs to be cut and welded
after cutting, make sure you protect your door while tacking it together!!!
UltimatE 01-10-2010 05:26 PM
Pretty straight forward modification, its great to see with the pictures you posted how easy it really is. This really opens up possibilities for us YJ guys that have, for the most part, been soft top or hard doors with no options.
texas_yj 01-10-2010 05:29 PM
I discovered that some doors may hit the fiberglass of the top, mine just nicked it, so I filed it to clean it up and repainted it
You will need to remove the YJ belt rail, the TJ doesn't use it and has a nice seal on the bottom instead
I had to trim off the tail on the rear part of the seal, tapper cut it so that it seals to the door nicely.
You will have to play with the pins alittle to get everything to align right, but one you get it right, it seals up nicely, Mine is as quite going down the road as my full doors, it has no leaks anywhere, and you cant see light from anywere around the door. I had to shorten the middle and last pin so they would sit lower on the door, and tweeked the front pin to hold it higher.
texas_yj 01-11-2010 07:27 AM
This pic didn't make the writeup, but does a real good job of showing how well the frames fit the hard top so I'm throwing it out there
Burlbook48 01-11-2010 07:59 AM
Very cool! Seeing the pic makes it clear exactly how the pin needs to be modified.
Looks good, too. Wonder if anybody makes white uppers to match my white hardtop? My Bestop soft uppers are spice to match my Supertop.
impboy65 01-11-2010 09:04 AM
Dang, you beat me to it. Looks great, I just got my uppers last night.
rustywrangler 01-11-2010 10:01 AM
Added to the FAQ.
2GPS4ME 02-09-2010 08:01 AM
Originally Posted by rustywrangler (Post 8667139)
Added to the FAQ.
Thanks, I wish I could get the Cherokee moderators to do that once or twice in a decade.... :rolleyes:
UltimatE 02-09-2010 09:22 AM
You might be able to adjust the spreader bars on the roll bar to pull the windshield back ever so slightly. This will move the hard top back as well and clear the doors properly.
sebastian22 02-09-2010 09:46 AM
Great write-up and excellent pictures. :thumbsup:
I have seen the question a million times, and its always been one of those subjects where someone thinks it might work. Thanks for clearing it up with so much detail.
2GPS4ME 02-09-2010 02:37 PM
Does anyone have some pictures of how the YJ soft upper does (not) fit on the hardtop? I am having troubles seeing why it would not fit.
UltimatE 02-09-2010 02:52 PM
There are no companies that make YJ soft uppers to fit hardtops. The only one that does is BesTop for their Supertop soft top, and the Supertop corners are a different radius and angle from the stock hard top. Why ? No idea.
2GPS4ME 02-09-2010 06:42 PM
I guess I'll go see for myself.
The radius of the top corner must be very close, because looking at pictures there is not much difference.
SimonTuffGuy 02-09-2010 07:06 PM
Wrong... There is a company. I purchased a set of them prior to giving in and buying my Bestop Hard uppers a few years back. The only problem is that they didn't fit as promised and the quality was nowhere near that of Bestop. Can't remember the brand anymore... I posted it several years back if you feel like searching my posts a bit.
CLIMBaMTN 02-09-2010 10:01 PM
not much difference? LOL...TJ has ROUNDED corner, YJ is SQUARE....if you don't believe me you can check my classifieds and see the YJ ones im selling...you can use them with a hard top, but you will have to SLAM the door to get it to close, and it will overlap and look like ****.
The time now is 11:02 AM.
