How to install a smittybilt XRC 8 winch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How to install a smittybilt XRC 8 winch
Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-18-2009, 11:05 AM   #1
kingkong1
Just ordered the winch and was wondering what i need to istall it to my stock bumper?
Thanks
Dom
kingkong1 is offline   Reply With Quote
Unread 02-18-2009, 11:12 AM   #2
makaioM3
I believe it comes with the requirred parts other than a two post battery & winch plate. I believe for optimum performance (battery life) you are going to need a two post battery if you don't already have one. You will also need a winch plate to mount it to if you didn't order one or already have one. You can make your own which many have done, or purchase one commercially made.
97 TJ 4.0 Automatic
makaioM3 is offline   Reply With Quote
Unread 02-18-2009, 11:12 AM   #3
Douglas S.
you will need a winch mounting plate
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S, Lightforce 240's, OME 2.5", 34" Toyo MT's, OEM Snorkel
1987 YJ Laredo
Douglas S. is offline   Reply With Quote
Unread 02-18-2009, 11:15 AM   #4
Brandon_YJ
1987 YJ Wrangler
You will need a winch plate with the standard pattern mounting holes (4.5"x10") for 4 3/8" bolts.
The winch also includes a fairlead, so make sure your winch plate can mount one of those as well, not sure the distance apart for the fairlead.
It comes with everything else. I have one.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using Elinks in a (text only) terminal. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused click here to see how I view the forum.
Brandon_YJ is offline   Reply With Quote
Unread 02-18-2009, 11:36 AM   #5
kingkong1
where can i purchasw a standard winch plate with roller attachement
Unread 02-18-2009, 11:41 AM   #6
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
any 4x4 shop can get thm 4 you. there pretty easy to make if your so inclined. i have pics if you need them
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showt...hp?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline   Reply With Quote
Unread 02-18-2009, 11:42 AM   #7
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
as far as a two post battery, i just added a nut to the original battery clamp
Unread 02-18-2009, 11:43 AM   #8
rip_1986
i just bought the same winch got every thing for just under 400
92 yj 355 sbc holley pro jection 700r4 231 hd D30/8.8 4.88 gears 4in RC 1.5 booms 3in body tummy tucked on 35s + goodies
98 zj 4.0 2in pucks on 31s her DD
89 mj 4.0 stock for now my DD
71 76 cj5 sold
72 cj5 forsale to fund mj build
rip_1986 is offline   Reply With Quote
Unread 02-18-2009, 12:02 PM   #9
kingkong1
thanks just ordered the one from rough country
Unread 02-18-2009, 08:13 PM   #10
ugmo
I got one from SB, but wished I knew about the one from Harbor Freight. It is universal and cost about 1/2 what I paid.
ugmo is offline   Reply With Quote
Unread 02-06-2010, 10:58 PM   #11
tnboywhotravels
Anyone had issues mounting it. I am mounting, with a Smitty plate. I had to drill through my warn bumper for the two post closest to the grill. Problem is, right underneith the warn bumper is the tube/frame bumper. So it's going to be a challenge for those bolts. It looks like they want the bolts mounted upside down, nuts on the top. Anyone else have this issue?
thanks
tnboywhotravels is offline   Reply With Quote
Unread 02-07-2010, 12:42 AM   #12
MWguy101
I installed an the same winch on an Smitty plate. Its not a bad install. On mine, I did not have to drill any new holes. I did use lock tight on all the bolts. I live in an apartment and was worried some one might try to jack it. I pulled out my factory jack and use the screw holes to ground the winch. Its a good buy, I have used my several times. The only down side to it, is the cable is not that long.
MWguy101 is offline   Reply With Quote
Unread 02-07-2010, 01:34 AM   #13
Fhajad
thanks
Take off the bumper, mount it on, then put it back on?
Fhajad is offline   Reply With Quote
Unread 02-07-2010, 03:54 AM   #14
joshbaker92yj
I have used mine for the last year. When i did the frame swap i got new grade 8 bolts and grade 8 washers and shimmed the front and back so that the winch plate was leve and not resting on anything but the washers.
Josh baker
joshbaker92yj is offline   Reply With Quote
Unread 02-07-2010, 05:23 AM   #15
RandyYJ
I ordered mine about two months ago from 4 wheel parts. $275 shipped to my door. (XRC8K)
If you're not on the edge, then you're taking up too much room.
RandyYJ is offline   Reply With Quote
