how important is drop pitman arm - JeepForum.com
post #1 of 21 Old 03-08-2010, 04:58 PM Thread Starter
CALUfootball64
just installed 4", how important is the new arm? cant for the life off me get the old one off. i tried pounding it with a hammer and, tried a gear puller it keeps sliding off
also after putting in new lines and such my brakes are soft as heck, they go all they way to the floor but do slow me down
any suggestions or info
94' yj, 8.8 LSD, 4" + 1.25 shackles on 32x11.5's
95 YJ new 2.5, rust free, rhino lined, leather bucket seats, DD
14 limited Grand Cherokee Eco diesel. The "wife's car"
CALUfootball64 is offline
post #2 of 21 Old 03-08-2010, 05:00 PM
BondoBbad
Not sure on the Pitman arm but did you bleed your brakes when you installed the new lines?
BondoBbad is offline
post #3 of 21 Old 03-08-2010, 05:04 PM
95jy
you really need it there is a pitman arm puller real cheap at harbor frieght
95jy is offline
post #4 of 21 Old 03-08-2010, 05:12 PM
biggn235
DAS Man
biggn235's Avatar
2014 JK Wrangler
The gear puller won't do it. I bought a pitman arm puller from a local Autozone and then returned it when I was done.
Be sure to spray some PB blaster on it too.
14JK -
98XJ
Past - 95YJ 99XJ 98XJ 05WK 94XJ
biggn235 is offline
post #5 of 21 Old 03-08-2010, 05:12 PM Thread Starter
CALUfootball64
several times
post #6 of 21 Old 03-08-2010, 05:13 PM Thread Starter
CALUfootball64
lmao how much did it cost before you returned it
post #7 of 21 Old 03-08-2010, 05:15 PM
95jy
there like 15 dollars
95jy is offline
post #8 of 21 Old 03-08-2010, 05:49 PM Thread Starter
CALUfootball64
does it do anything crazy? any spells, chants, or dances you have to do i couldnt get this thing to budge
post #9 of 21 Old 03-08-2010, 05:51 PM
95jy
95jy is offline
post #10 of 21 Old 03-08-2010, 06:25 PM
YJames90
YJames90's Avatar
cut the arm where it wraps around the shaft verticaly with a sawzall. Then split it with a chisel
My 2.5 to 4.3 swap thread
YJames90 is offline
post #11 of 21 Old 03-08-2010, 06:35 PM Thread Starter
CALUfootball64
any suggestoins for brakes?
post #12 of 21 Old 03-08-2010, 06:53 PM
scooter18155
1983 CJ7
I just bought a puller from autozone cheap enough that it was worth keeping for future use and it worked great and will get some more use soon.
scooter18155 is offline
post #13 of 21 Old 03-08-2010, 07:01 PM
wildman90
i have suggestions for both
brakes- bleed again and then maybe adjust the rears out till they just do drag a little. bleed the rears first, then the front. you will use up most of a quart of fluid.
pitman arm- heat the outside of the arm with an acetylene torch. not a propane. the usual torch we use for soldering does not get hot enough-fast enough and normally results in a ruined seal. i broke a 4 ton bottle jack getting one off!
good luck!
nothing i cant do--i'l pay myself $50/hr labor!!
the only thing you cannot do, is that which you have already accepted defeat!
many people search for god in the eleventh hour, only to die at 10:30
wildman90 is offline
post #14 of 21 Old 03-08-2010, 07:12 PM Thread Starter
CALUfootball64
good luck!
how can a ajust the back this was my first time tearing my jeep apart, man it feels good! but god damn does it get frustrating ! almost finished just need that pitman arm and brakes cleaned up
post #15 of 21 Old 03-08-2010, 07:58 PM
YJake
I broke a regular puller's arm off and ruined my bench mounted Vise trying to get a pitman arm off... I will try again someday but I'm currently busy looking for a new vise and puller.
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
Do I need a drop pitman arm? Ptr YJ Wrangler Technical Forum 12 02-03-2010 03:45 PM
Drop Pitman Arm demon67 TJ Wrangler Technical Forum 14 01-03-2010 12:49 PM
looking for drop pitman arm with more drop than typical 4" DPA swa240z YJ Wrangler Technical Forum 3 04-18-2008 12:35 PM
T-case drop and drop pitman arm??? snakester14 TJ Wrangler Technical Forum 18 08-30-2007 06:40 AM
drop pitman arm and pitman from XJ bighair YJ Wrangler Technical Forum 4 05-28-2002 01:10 PM
