How I fixed the rear frame rust by the shackles on my YJ - JeepForum.com
post #1 of 19 Old 04-17-2010, 07:21 AM Thread Starter
0llllll0
1967 CJ5
I bought a 92 YJ for a deal because the rear section of the frame at the shackles was rusted on both the drivers and passenger sides. I took the gas tank out and started grinding... Once I got everything cleaned up I started measuring and designed ( using Catia V5 ) a set of 1/8" plates to go over the rusted area. With the 1/8" plates you can still use the stock bushings and shackles. The steel sleeve that the shackle bushing fits into actually sticks outboard of the frame about an 1/8" on both sides of the frame so it works out perfect... I also incorporated the factory frame holes / slots, but I over-sized them so there was room to weld the plates to the frame in those areas as well as the edge of the plates. When I had the design complete, I had the plates laser cut and started welding. Here are some pics of the results from start to finish.
After I completed my Jeep, my brother in-law noticed his frame was bad in the same area, so we fixed his the same way, then another friends and another friends and so on and so on... The repair on my jeep is going on 2 years now and it's held up great!
Ken
jeepoholic@me.com
0llllll0 is offline
post #2 of 19 Old 04-17-2010, 07:46 AM
jeepinmichguy_
very nice!
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #3 of 19 Old 04-17-2010, 08:11 AM
Area.3.Fiftyone
Nice job.
There is one thing that I would like to mention though.
You should never weld a plate directly horizontal (perpendicular to the rail). It will lead to stress cracks in that area. You should fish mouth the edges of the plates like this: < > instead of having them straight up and down.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #4 of 19 Old 04-17-2010, 09:06 AM
prflyer
nice, this is in my immediate to do's on mine!
prflyer is offline
post #5 of 19 Old 04-22-2011, 08:19 AM Thread Starter
0llllll0
1967 CJ5
0llllll0 is offline
post #6 of 19 Old 04-23-2011, 02:47 PM
CALUfootball64
Mine needs done.immediately also any way I can get dimensions and plans off of you?
94' yj, 8.8 LSD, 4" + 1.25 shackles on 32x11.5's
95 YJ new 2.5, rust free, rhino lined, leather bucket seats, DD
14 limited Grand Cherokee Eco diesel. The "wife's car"
CALUfootball64 is offline
post #7 of 19 Old 04-23-2011, 03:07 PM
giggityjeeper
you didnt cut the bad **** out??
just welded over it??
man I cut the **** out and replaced it.... couple years that will just rot out from the inside...
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #8 of 19 Old 04-29-2011, 03:00 PM Thread Starter
0llllll0
1967 CJ5
It's been 3 years now and it's holding great! I make sure and keep it clean back there by flushing the frame out with a garden hose. But other than that it is nice a solid .
0llllll0 is offline
post #9 of 19 Old 02-02-2012, 11:23 AM Thread Starter
0llllll0
1967 CJ5
0llllll0 is offline
post #10 of 19 Old 02-02-2012, 11:34 AM
srwilson8074
Purple Power has a rust inhibitor and is a liquid that can be sprayed with a spray knozzle inside the frame. It turns the scale to a hard black finish. Get a snake eye and look inside the frame and if it is coated good foam fill it. get the expandable stuff and cut off the excess. Does anyone know what a new frame goes for "aftermarket" for a 88-95 wrangler??
S.R. Wilson Sr
srwilson8074 is offline
post #11 of 19 Old 02-02-2012, 01:54 PM
KSRick
I found one listed at $2,395.99.
KSRick is offline
post #12 of 19 Old 02-02-2012, 02:12 PM
srwilson8074
I think I can custom build one cheaper it like $500.00 for material, US made steel. Got to check with legal and see if I can do this. Thanks
S.R. Wilson Sr
post #13 of 19 Old 02-02-2012, 03:19 PM
monkeyhouse
Put me down for one!
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #14 of 19 Old 01-25-2013, 02:59 PM Thread Starter
0llllll0
1967 CJ5
If I could buy a new YJ frame for $500, I would build a new Jeep for sure !
0llllll0 is offline
post #15 of 19 Old 01-25-2013, 03:03 PM
NHfireLJ
NHfireLJ's Avatar
Paid $500 for a GREAT used frame. WORTH IT
ALSO check out Auto Rust Technologies replacement frame parts. Q tec has them... Thats How I started.... but eventually the rust won... CURSE YOU METAL OXIDATION!!!
SOLD
YJOTM FEB 2013
NHfireLJ is offline
frame , kit , repair , rust , wrangler
Rusted frame..can it be fixed/welded? DamonsYJ YJ Wrangler Technical Forum 3 10-06-2008 06:34 AM
Frame fixed and I am tired but have new question molsenice YJ Wrangler Technical Forum 17 03-12-2008 05:32 PM
Need Frame Fixed!!!! 05NHWrangler YJ Wrangler Technical Forum 3 03-08-2008 09:39 AM
Rust on Rear frame - 94 YJ ShaneS YJ Wrangler Technical Forum 16 05-08-2007 01:16 PM
Frame Rust ASUsax TJ Wrangler Technical Forum 3 10-13-2006 11:54 AM
