How hard is it to replace windshield hinges? - JeepForum.com
post #1 of 38 Old 06-05-2006, 05:40 PM Thread Starter
MayorMcCheese
In a couple of weeks I am going to replace the cowl seal under the windshield, so it will need to be dropped. While I'm at it I thought I might just go ahead and replace the windshield hinges because it looks like the PO tried to paint them and use some kind of caulk to seal them.
So, like the title says, how hard is it to replace the hinges on the windshield? Quadratec lists it as being an "easy" and able to be completed in under 1 hour.
TIA
-Evan (YJ noob)
1990 YJ 2.5L
Stock everything... for now.
MayorMcCheese is offline
post #2 of 38 Old 06-05-2006, 05:44 PM
Rocky529
Rocky529's Avatar
Appears easy, but if you strip one of the torx screws... you'll be kicking yourself for ever starting the project.
Definitely get a breaker bar and 2 people... one to apply pressure and the other to turn the bolt.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 38 Old 06-05-2006, 06:15 PM
gmcz7198ba
OH NO NOT WINDSHIELD HINGES!!
Like posted above its a simple job till you strip a torx then you will be screaming!
87 YJ 4.3l, TH350, 35's
95 YJ 2.5l, lifted, 33's
gmcz7198ba is offline
post #4 of 38 Old 06-05-2006, 06:17 PM
mmasuperman12
yeah i jsut had to take my windshield off and i am contimplating gettin a new windshield insted of dealing with taking the hinges off (have to fix the rust for the glass company to guarentee it) may not be cheaper but it may be easier
mmasuperman12 is offline
post #5 of 38 Old 06-05-2006, 07:19 PM
wwiihistory
wwiihistory's Avatar
getting to the nuts on the back of the lower front hinge bolts is fun (drivers side). Remove the 3 dash screws next to speakers and pull out, then stuff something in there to hold dash back so speaker magnet won't grab your wrench so bad.
Happiness is a belt-fed weapon
95 Sahara, 4.0L, 5 spd, Olive/Tan, HT,HD's, 31's,3.07s
Military Jeep club member 1941,1942,1943,1944, and 1945
wwiihistory is offline
post #6 of 38 Old 06-05-2006, 08:49 PM Thread Starter
MayorMcCheese
So the first fun part is getting to the nuts behind the dash....
then I just have to worry about not stripping any torx bolts.
Sounds like fun.
Correct me if I'm wrong, but I thought that the whole trick to torx bolts was just using the correct size bit???
-Evan (YJ noob)
1990 YJ 2.5L
post #7 of 38 Old 06-05-2006, 09:23 PM
DustinM
DustinM's Avatar
Definatly buy a couple extra torx bolts. You WILL strip at least one out...almost guaranteed! They are relativley easy to find through almost any Jeep vendor. I stripped 2 of the 16 out and had to drill them out. Not bad, but make sure to have extras. Just my 2 cents.
1994 YJ Sahara SOLD
2003 TJ Rubi
DustinM is offline
post #8 of 38 Old 06-06-2006, 10:57 AM
atomicmoose
Just call me Moose
atomicmoose's Avatar
I had to drill out 4....I hate working on that area of the tub. Everything is so tight.
atomicmoose is offline
post #9 of 38 Old 06-06-2006, 11:44 AM
Flashfoto
If you think it would be fun to pull your own wisdom teeth, without novacain, then this job will really make you happy!
LOLOL!
Flashfoto is offline
post #10 of 38 Old 06-06-2006, 01:26 PM
RckyMntnKng
yep, after replacing the Dash speakers i agree (Lowered glass, removed dash)....PITA
1991 YJ
SOA on 33's
42 yr old 8k Warn 5687
RckyMntnKng is offline
post #11 of 38 Old 06-07-2006, 05:21 PM Thread Starter
MayorMcCheese
Well thanks for all the encouragement and enthusiasm guys.
I was looking at the hinges again yesterday and I'm almost sure that I should just go ahead and bite the bullet and replace them.
-Evan (YJ noob)
1990 YJ 2.5L
post #12 of 38 Old 06-07-2006, 06:34 PM
JHcujo
Okay well maybe I just got lucky but mine were not bad at all. I had to drill out 2 of them. I had to use a "F" bit for my drill and just retapped the threads. One thing that I will say is PB Blaster is wonderful. Go slow,spray the bolt and work it back and forth.
JHcujo is offline
post #13 of 38 Old 10-08-2011, 05:56 PM
mbedit
Old topic, but it came up when I googled replacing windshield hinges.
Last week I went to replace the factory speakers in my '91 YJ... and while removing the dash, the Driver Side Windshield Hinge was so rusty it actually bent when forced the shield down :-(
So, I figured no biggie I'll replace the hinges, but I figured I should google up some advice to see if their'ed be any gotchas.
Thats how I found this thread and forum!
Anyhow, you guys wen't kidding! Things were going well, and then I stripped the last Torx bolt on the upper windshield of the passenger side.
So I went to drill it out, and after drilling a while I came up with the idea to try and "tap" a wedge into the remaining bolt in hopes I could grip it and drive it back out.
That was a bad Idea.
I ended up knocking the bracket that receives the two bolts in the windshield frame loose :-(
I put that aside and turned to the lower bolts. The ones with nuts. But my YJ still had all the original factory putty on the nuts. It took me about an hour of scraping and messing about just to get the easiest one off on the passenger side and I knew there was no way in heck i'd be able to get up in the driver side and scrape all that off.
Thus I decided that drilling out the remaining 7 and just putting new nuts on it would be quicker and less of a hassle.
So... I drilled the rest out and replaced them all, which at this point went surprisingly smooth!
But I still had to figure out how to fix my passenger side. I removed the entire windshield, and was able to "shake" the bracket down to the wiper access hole.
Removing the bracket revealed I needed to bet the rest of the bolt out of it anyhow, so I fixed that and luckily I didn't damage the threads or anything on it.
Finally I came up with the idea of string some wire through the hinge bolt holes and out the wiper access hole, connected the bracket to the two holes and gingerly worked it back into position using the two wires like a marionette! Amazingly it worked... thought it took two trys, and I was able to string the wire through the new hinge, into the bracket, and screw the new hinge bolts in!.
Anyhow, basically, you guys weren't kidding... it turned into a whole day chore, and I had to drill 8 bolts.
mbedit is offline
post #14 of 38 Old 10-08-2011, 07:19 PM
nembudonna
Takes about an hour!! Who are they kidding. You have to pull the dash and then hope the bolts come out. I spent 3 hours just curseing jeep about that cr@p.
nembudonna is offline
post #15 of 38 Old 10-09-2011, 05:36 AM
jonny93yj
I guess i got lucky. I removed all hinges to be replaced with new after jeeps painted. I didn't remove the dash ( there's no dash speakers to grab my wrench ) and had my wife turn a couple of bolts while i held wrench on nuts behind dash. No stripped heads or broken bolts, did donate a bit of knuckle blood. I'd say less than an hour to remove. Not sure about install time yet.
jonny93yj is offline
Cosmetic fixes? door hinges rusty and hard top window hinges peeled............... hangwire TJ Wrangler Technical Forum 8 08-25-2009 02:39 PM
Hex bolts for windshield hinges? How do I seal the hinges? ZeroGravity YJ Wrangler Technical Forum 4 05-20-2009 09:34 PM
Anyone had to replace their TAILGATE HINGES? pimpinken.net TJ Wrangler Technical Forum 24 08-06-2006 09:29 AM
Anybody replace their door hinges? MR.CLIFFORD TJ Wrangler Technical Forum 6 11-18-2004 10:07 PM
anyone ever replace all the hinges with chrome? joeydominick YJ Wrangler Technical Forum 12 10-08-2004 03:25 PM
