How hard is it to remove NP231 T-case??? - JeepForum.com
post #1 of 3 Old 02-05-2002, 02:01 PM Thread Starter
bobznew
Is this a task for more than one person?
What tools are needed, besides the obvious (wrenches, jacks, etc.)?
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #2 of 3 Old 02-05-2002, 04:35 PM
Tailgummer
Its not hard. An extra hand is helpful just to lower the T-case as it will be above your head. Otherwise, support tranny and remove skid plate. Remove both driveshafts (leave the slip yoke in or drain the oil first)Remove the shifter assembly (3 bolts as I recall) unplug the vacumn switch plug and speedometer cable. Remove the nuts from the approx. 10 studs that hold the tcase to the tranny. Slide aft and lower. No special tools needed other than jack stands and box wrenches (metric)
Good luck and email me if you have any questions.
Chuck
Good Luck
Chuck
'91 YJ, 4.0L 5sp, Atlas II, RE SOA + 2"BDS, 35" Explorer Xterrains, ARB's & 4.56 gears, WARN 9000i
WWW.4x4xnorthwest.com
Tailgummer is offline
post #3 of 3 Old 02-05-2002, 06:31 PM
JeeperJay
As long as you don't have any problems with the mounting studs fusing to the trasmission case like mine did, it'll be a easy job.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
np231 transfer case outer front case liftedblackjeep TJ Wrangler Technical Forum 3 06-11-2009 06:32 PM
How hard is it to remove hard door glass? T.H's TJ TJ Wrangler Technical Forum 3 06-03-2006 01:07 PM
NP231 T-Case Wheels4186 TJ Wrangler Technical Forum 4 10-01-2005 08:01 PM
np231 t-case ST33LR4T YJ Wrangler Technical Forum 7 06-01-2004 11:44 AM
NP231 T Case jthumper35 YJ Wrangler Technical Forum 7 09-16-2002 10:53 PM
