How hard is it to change timing chain?
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |
So how difficult is it to change the timing chain in a '95 2.5l? Will I have to deal with oil or coolant? The only place I have to work on the Jeep in the winter is at work but I can't be spilling oil and coolant in the backroom with $100's of thousands of dollars of fitness equipment all around. Any tips on this would be great appreciated as this is a problem that is only getting more and more annoying.
#2 |
It cost me $420 at a garage because I didn't feel like dealing with it.(Too cold for me with no garage). It's was driving me nuts for years. Check this link out. http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1f/e0/a1/0900823d801fe0a1.jsp
#3 | |
#4 |
If you can do the following steps without removing the radiator, you can get away with a fairly clean job:
1. Remove Fan & shroud, 2. Remove Drive Belt, 3. Remove Vibration Damper, 4. Remove Timing Case Cover, 5. Rotate the crank to line up the two timing marks on the gears, 6. Remove Oil Slinger, 7. Remove Camshaft retaining bolt & now the two sprockets and chain come off as an assembly. 8. Install new chain and assemble in reverse order. |
#5 |
wow that sounds easy. thanks Alfons and everyone else for that matter.
#6 | |
#7 |
You will need a harmonic balance type puller to get the vibration dampner off..
Not a hard job at all - as long as you have the tools to do it.
95 YJ 2.5L 5 speed, 4.88's, Aussie Locker D30, 35" Mud Rovers, Herculined tub, TKH rear bumper, Ford 8.8, JB Conv. SYE, Sylvania Silver Stars, T-MAX 9K winch, MORE 1" body lift, Turbo City oil pan skid, Rubicon Express 4" lift... |
#8 | |
Anyway, if I'm wrong I'm out about $30 with a new timing chain and gears and the new found knowledge. If I'm right, which I hope I am, then the Jeep will run better and I'll have some bragging rights. Well, not really but the Jeep will run better. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
