Quantcast How hard is a body lift. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How hard is a body lift.
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 01-05-2004, 05:27 PM   #1
TheHerald
I got a daystar poly urethene body lift kit. It is only 1 inch so i can get body armor and such in the future. Anyway, How hard is this? What is the time estimate. Keep in mind i have never done this.
I will be doing this with one of my friends. Any tips? Things you wish you had known before yo ugot into it?
I have heard to allocate 5 hours, and thats ok, but anything else?
Recommend more time? Any prep work i should do?
Thanks a lot.
[COLOR=olive]Champagne Jeep Club Member #3[/COLOR]
94 Jeep Sahara, 6 cyl, 5spd,Soft top.
1 inch Daystar body. Herculined. I know it ain't much but I take it like you should off-road. Slowly.
TheHerald is offline   Reply With Quote
Old 01-05-2004, 05:31 PM   #2
smok3y
spray all the body mount bolts with some lubricant of some sort to get any deposits or rust broken up to make the bolts easier to get off, wd40, pbBlaster,liquid wrench take your pick
1990 YJ/ 31x10.50 Maxxis Mudders/Removed Sway bar,Rear trac bar/tow hooks. 2" straight pipes from manifold back
[COLOR=white]White Jeep Club #73,999,999[/COLOR]
smok3y is offline   Reply With Quote
Old 01-05-2004, 05:31 PM   #3
DanG
Thanks a lot.
spray all the bolts with pb blaster or simalar product every day for couple days ahead of time. other then that it is simple, just follow the directions . took me 2-1/2 hours by myself with no help.
89 RED YJ
sitting in driveway next to wrecked car
[URL=http://www.cardomain.com/id/djg6678]my jeeps page[/URL]
[SIZE=4] [COLOR=red]NE[/COLOR][COLOR=white]Off[/COLOR][COLOR=blue]Roading[/COLOR] [/SIZE]
H2RT MEMBER
[color=red] RED JEEP MEMBER #49[/color]
POS JEEP MEMBER #3
DanG is offline   Reply With Quote
Old 01-05-2004, 06:20 PM   #4
Lyle36
i installed that kit the other after i got it off ebay, its pretty simple, and im only 17 so ya know, took me like 3 hours maybe
95 YJ 4 banger
Self-made Intake
31x10.5 mudders
rear bumper off TJ
Pacesetter TFX Exhaust System
Daystar 1" Body Lift
cowl inducted fiberglass hood
Summit Racing Seats........just geting started
Lyle36 is offline   Reply With Quote
Old 01-05-2004, 06:52 PM   #5
BigDJeep
With two of you working 5 hrs should be a safe bet. If you have no problems it should only take you 2 hrs easy. Like others have said spray all the bolts before you start. Spray them every day for about a week before you start. Be aware if bolts break or nuts spin it's gonna increase the time greatly. It took me 2 days to do mine but I had the passenger rear bolt breal and the driver front nut spin. I also painted the frame while I had the body raised up. Good luck. If you run into any problems give me a shout.
01 XJ Sport, 4.0, Auto, 30x9.5-15 BFG AT's, 15x8 Rock Crawler Type 97's w/ 4.5 back spacing, 2" Rubicon Express Lift w/ Shocks, Front tow hooks, Front bumper aux light bar, (3) Pro Comp 100wt Driving Lights, AirRaid Cold Air Intake. (Rusty's High Flow Exhaust w/ 50 Series Flowmaster, Rear Locker Coming Next!)
Other Vehicles:
99 Nissan Pathfiner SE 4x4
87 Toyota PU (Beater)
BigDJeep is offline   Reply With Quote
Old 01-05-2004, 07:42 PM   #6
Moxley
TheHerald,
This thread should help
http://www.jeepforum.com/forum/f37/1-body-lift-installation-difficulties-46006/
Later,
Doug
1995 YJ Wrangler - 2.5 Liter, 5 Speed Trans
4" Lift (3" Suspension, 1" Body) - 31" Firestone Tires
Outlaw II 15x8 Rims - 6" Best Top Fender Flares
[color=darkred][b]My Jeep:[/b][/color]
[url]http://members.myactv.net/~douglas.moxley/jeep.jpg[/url]
"A high IQ is like a Jeep; you will still get stuck, just farther from help"
Moxley is offline   Reply With Quote
Old 01-06-2004, 08:00 AM   #7
JayJEEPguy
I got lucky I guess. I did my DayStar 1" body lift on Sunday night. Took me a little under 2 hours to perform it. All I have to do now is remount my radiator fan shroud.
I should have sprayed all of the bolts beforehand, but for some reason I didn't. Every bolt came out easy on mine .
Good luck.
Jason T.
'05 Saab 9-5 Aero: Black. Turbocharged Swedish goodness
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hearKolak 3" exhaust sound clip
http://www.cardomain.com/id/MourningWoody
JayJEEPguy is offline   Reply With Quote
Old 01-06-2004, 11:11 AM   #8
DavesMatthew
I was just wondering how bad of a shift linkage problem you might have with a 3" body lift.
DavesMatthew is offline   Reply With Quote
Old 01-06-2004, 10:21 PM   #9
RideRed04
I put a 2" on, and now that it's getting cold, the boots cause my 4x4 to pop out untill the it gets soft enugh to stay locked in. 3" would be even worse, unless you extended the shaft. My tranny doesn't give me too much trouble, it has to be really cold (10 below seems to do it once or twice) for the tranny to pop out.
1989 YJ: 3.5" of lift, 36" irok's, warn 9.5ti, d44's
1998 XJ classic for DD, a little lift, a little tires
RideRed04 is offline   Reply With Quote
Glock Forum
