Quantcast How good are Aussie lockers for Dana 30? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How good are Aussie lockers for Dana 30?
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 10-16-2008, 06:50 PM   #1
Dmax5er
I got my gears for the front axle and i'd like to put a locker in there while im setting up the front end, Is Aussie a good locker for Trails, mud and some light duty crawling?
Or how about Lock Right?
What Day is it?
Firefighters Jeep Club- Administrator
http://groups.jeepforum.com/Firefighters_Jeep_Club
Dmax5er is offline   Reply With Quote
Old 10-16-2008, 06:58 PM   #2
jbolty
ISO 9001 Compliant
jbolty's Avatar
best thing I have done to the jeep, so far.
Originally Posted by Stimpdezracer View Post
Cross threading is as good as lock-tite
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Old 10-16-2008, 07:04 PM   #3
Dmax5er
do you still have the axle disconnect in yours?
What Day is it?
Old 10-16-2008, 07:05 PM   #4
BYuen
Wahoowa
BYuen's Avatar
The Aussie is good for anything off road really. A LockRight is the same design as the Aussie, just a bit more expensive and American made.
White 01 TJ Sport 4.0 NV3550
BYuen is offline   Reply With Quote
Old 10-16-2008, 07:10 PM   #5
fyrdriver
One firefighter to another...get the aussie! If you have the axle disconnect its invisible on the street, no clicking, no noise, period. I had to have my front driveshaft balanced from some vibes but the traction is awesome. For the money its a great investment!
fyrdriver is offline   Reply With Quote
Old 10-16-2008, 07:36 PM   #6
93YJfalcon
If youre running 35"tires as your profile says then I'd reccomend at least TJ shafts if not Chromolly axles unless youre really really easy on the go pedal. IMO it's no fun wondering if your going to break and hold up trail traffic. I have a similar set up to yours and Yukon front axles I still carry TJ shafts as spares.
Edit: BTW the Aussie works great and is a very easy setup!
ROCK OVER LONDON... ROCK ON CHICAGO!
http://dirtyfabworks.com/gallery.htm
93YJfalcon is offline   Reply With Quote
Old 10-16-2008, 07:40 PM   #7
dbikers
it's one of the best things i've ever done to mine...i still have the disconnect workin'
mine's never made a peep up front......
STUPID HURTS.......OUCH!@#$
dbikers is offline   Reply With Quote
Old 10-16-2008, 08:13 PM   #8
jbolty
ISO 9001 Compliant
jbolty's Avatar
disconnect is still in and working. I kind of need it like that because I flat tow sometimes.
Old 10-16-2008, 08:14 PM   #9
Dmax5er
Good eye there falcon...
Axle upgrade is coming also, but funds are slow... going with aussie and stock axles then ill repull them and put in yukons with balanced DS. $$$$ Thanks
What Day is it?
Old 10-16-2008, 08:26 PM   #10
Dmax5er
does that mean if you done a Tj axle swap you couldnt flat tow anymore?
What Day is it?
Old 10-16-2008, 09:16 PM   #11
93YJfalcon
You could always disconnect the axle side of the drive shafts. Only 8 little bolts for a complete disconnect from the t-case. Then just strap the shafts up between the framerails.
Old 10-16-2008, 10:01 PM   #12
MLJeeper
MLJeeper's Avatar
Another thumbs up for aussie
Your limited slip differential sucks.
MLJeeper is offline   Reply With Quote
Old 10-16-2008, 10:18 PM   #13
jbolty
ISO 9001 Compliant
jbolty's Avatar
Short answer is, it depends. The locker should ratchet enough to allow it to turn around corners or it may not. Some people have good luck others don't. In my case I have one of the transfer cases that does not have a "true" neutral. When it is in N the drive is disconnected but the front and rear are still connected to each other so towing is a problem, unless I disconnect the drive shaft on the front.
I still love my aussie and would recommend it highly
Glock Forum
