How to get ice off softtop windows? - JeepForum.com
post #1 of 49 Old 11-06-2009, 09:32 PM Thread Starter
jeepoffroad18
I live in Ohio and i take my jeep to school in the morning. lately i have had a prob with ice (alot today)being on the soft top windows. how can i get it off quickly without scratching the windows? bc i dont hav time to sit and let the car warm up for an hour. and i end up having to unzip my windows to see when turning. which is gonna be a even bigger pain when its 15 degrees outside and im tired and not wanting to go to school anyways hhaha. and tips or ticks would be great thx
jeepoffroad18 is offline
post #2 of 49 Old 11-06-2009, 09:37 PM
Plato2k5
Just hit the window with your palm on the inside. Will get some of the ice to crack..... than I just use a credit card to scrape. No matter what you do they will get scratched... but they get beat up when I take the jeep through trails so it does not bother me.
Plato2k5 is offline
post #3 of 49 Old 11-06-2009, 09:39 PM
yjmoose
Be very careful with the idea above, I did this last year and now have a nice crack that runs the entire length of the window. I just let the jeep warm up now when it is parked outside.
yjmoose is offline
post #4 of 49 Old 11-06-2009, 09:41 PM
jeepmike20
i was always told to pout warm water over the windows
jeepmike20 is offline
post #5 of 49 Old 11-06-2009, 09:50 PM
rivalarrival
Stormaggedon
rivalarrival's Avatar
I'm going to be in a similar position - first winter with a Jeep, no hard top, and I'm up in Kent.
As I understand it, you don't even want to TOUCH the windows when they are below freezing. Apparently, they get quite brittle.
I'm planning on making cheap covers for my windows out of a tarp or a drop cloth or something. Open the door, drape the tarp over the door, close the door, and it should stay in place. I don't know how well it will work, but give me a few weeks and I'll get back to you.
Of course, you could run with the doors off - no visibility problems with that approach.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine
We work together every damn day. --Jon Stewart
Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it.
Low Output 4 Cylinder Jeep Club member #188
rivalarrival is offline
post #6 of 49 Old 11-06-2009, 09:52 PM
Plato2k5
I guess it does not get that freezing cold here in MI? I never had an issue... or perhaps I'm just lucky lol. I also try and drive the jeep only when needed
Plato2k5 is offline
post #7 of 49 Old 11-06-2009, 09:54 PM Thread Starter
jeepoffroad18
nice idea! tell me how it works
post #8 of 49 Old 11-06-2009, 10:05 PM
rivalarrival
Stormaggedon
I was hoping you'd tell me.
You'll likely see ice problems sooner than me - I work out of my home, doing mostly paperwork in the mornings. I don't get out of the house until 11AM-1PM
post #9 of 49 Old 11-06-2009, 10:10 PM
Apollo12227
A cheap vehicle cover that will cover the cab overnight should stop that from happening if u can't afford a cover then a tarp l anthing to keep the top from being exposed to direct contact from the moist air outside should keep that from happening. I had to do this in west Texas... It works the same as why orchard growers in Florida put tarps over the orange trees before a freeze, they won't get ice buildup on the leaves because they don't get directly exposed to the moist air which condenses when the sun goes down, therm freezes.
Apollo12227 is offline
post #10 of 49 Old 11-06-2009, 10:15 PM
azgurney
Move to Arizona. 88 degrees today.
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
post #11 of 49 Old 11-06-2009, 10:16 PM
dodger889
They do make a 12vdc heater / defroster that will do the job for you.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #12 of 49 Old 11-06-2009, 10:17 PM
wilywillie
The manual says the magic number is 42*.
It's colder than that in Richmond right now.........
wilywillie is offline
post #13 of 49 Old 11-06-2009, 10:39 PM
rivalarrival
Stormaggedon
A few years back, I had an oil-filled electric space heater on a timer in the back of my van. An hour before I had to leave, it would kick on automatically, pre-heating my cab and defrosting my windows. A cheap space heater gets too hot - something will melt or catch fire. An oil-filled heater doesn't get above 150-200F.
Of course, an oil-filled heater is too big for a TJ, and my daily routine isn't time sensitive anymore.
post #14 of 49 Old 11-06-2009, 10:52 PM
plowboy87
a ice scraper, i'm sure walmart sells them down there. just keep the blade flat and light pressure.
last year i didn't bother putting the hard top on, the only problem was a small crack in the back window when the temp dipped below -35*C for a couple days. so as long as it doesn't get that cold you should be fine
plowboy87 is offline
post #15 of 49 Old 11-07-2009, 12:31 AM
MJMPC
Get up a little earlier in the morning and let it warm up .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
Wax the new softtop windows? $lick TJ Wrangler Technical Forum 12 02-03-2008 12:25 PM
Mud on the softtop/windows PearlJam1003 TJ Wrangler Technical Forum 8 05-21-2007 08:24 PM
Softtop windows Feigle TJ Wrangler Technical Forum 7 11-30-2006 01:15 PM
Tinted Softtop Windows BLACK05X TJ Wrangler Technical Forum 3 07-28-2006 07:48 PM
Where do you store the softtop windows? Scratch TJ Wrangler Technical Forum 9 04-22-2002 10:58 AM
