How to get broken bolts out - JeepForum.com
post #1 of 24 Old 08-17-2011, 07:41 PM Thread Starter
houd1n1
exhaust manifold to head cylinder bolts are broken. both of them. Whats the easiest way to get them out? and how would I do that?
Please help, its causing my jeep to whine and whistle.. :/
houd1n1 is offline
post #2 of 24 Old 08-17-2011, 07:47 PM
phil1330
1964 CJ5
Drill a hole in the bolt, then get an easy-out to back it out.
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #3 of 24 Old 08-17-2011, 07:48 PM
Moto4x4
Yell at em for a while and they will back out
But yea easy out is the way to go.
Moto4x4 is offline
post #4 of 24 Old 08-17-2011, 07:51 PM
tdewit
Took the head to NAPA, $14 a piece, well worth it.
tdewit is offline
post #5 of 24 Old 08-17-2011, 08:37 PM
TheNewbie
+1. Just get a set of easy outs. If you don't have one now you'll need one at some point. Owning a YJ without owning a set of easy outs is kind of blasphemy.
You drill a hole in the middle of the bolt, then use the easy out to back the broken bolt out. It's kind of like a drill bit that has been cut in reverse. So when you turn it counterclocwise it wants to dig deeper into the hole that you just drilled. This causes it to bite into the metal and you can turn it right out.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #6 of 24 Old 08-17-2011, 08:40 PM
sbsg2005
Just don't break the easy out off or you will be hating life.
sbsg2005 is offline
post #7 of 24 Old 08-17-2011, 09:16 PM
Ziptied
Yeah, I just did that tonight. Now I'm trying to figure out how to drill through chrome vanadium steel.
Ziptied is offline
post #8 of 24 Old 08-17-2011, 09:36 PM
Peter Nuss
1987 YJ Wrangler
Just get a nut and place it over the broken bolt. Then weld the nut to the broken stud thru the hole in the nut. Then just unscrew the nut with the stud attached. Might take two or more time to weld it right if you are not a good welder.
Peter Nuss is offline
post #9 of 24 Old 08-17-2011, 10:06 PM
Ziptied
Not sure that would work since the bolt actually broke off inside the head. Meaning it's about 1/16 or more from the opening. I wouldn't want to jack up my threads.
Ziptied is offline
post #10 of 24 Old 08-17-2011, 10:55 PM
MJMPC
Drpll it out oversized and put a heli coil in it.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #11 of 24 Old 08-17-2011, 11:04 PM Thread Starter
houd1n1
Thanks everyone I will try it soon. Is it possible to do it without taking off the head?
houd1n1 is offline
post #12 of 24 Old 08-17-2011, 11:08 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yes it is, take your time and try not to feel overwhelmed by it. A good set of easy outs will help fix your problem.
Luck Favours The Prepared
Anticanman is offline
post #13 of 24 Old 08-17-2011, 11:36 PM
cubewhiz
Been there, done that. It sucks.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #14 of 24 Old 08-18-2011, 09:50 AM
Green95YJ
Man, if you want to drill it and then use an Easy Out make sure you center punch and drill a small pilot hole and then a larger hole. The larger hole needs to be almost out to the threads. If you do this and use a square easy out you wont have a problem. Biggest mistake is drilling a small hole and then snapping the easy out off. When you get the bolt out it should resemble a helicoil.
Green95YJ is offline
post #15 of 24 Old 08-18-2011, 08:34 PM
Ziptied
Well I snapped the easy out of in te damn bolt. Any ideas how to drill through it? I have a cobalt bit but it isn't doing anything. I to the point where I want to exchange heads!
Ziptied is offline
4 broken bolts! AustinCJer TJ Wrangler Technical Forum 13 11-18-2009 11:44 AM
Broken Bolts bringbackphish YJ Wrangler Technical Forum 1 12-14-2008 09:32 PM
Broken Bolts ? Smoke6 TJ Wrangler Technical Forum 9 07-31-2007 03:49 PM
Broken bolts merdas TJ Wrangler Technical Forum 5 12-03-2006 12:00 AM
Broken Bolts!!!! Help!!!! beyondink TJ Wrangler Technical Forum 5 06-27-2006 06:56 AM
