How to - Fuel tank removal - Page 4 - JeepForum.com
post #46 of 72 Old 09-29-2013, 01:17 PM
Nelliebelle7
Originally Posted by CrawlingForward View Post
Yeah, I forget who said it, but the supply line definitely is 3/8 on the tank side and 5/16 on the hard line side. Trying to use 5/16 to fit on both ends did *not* work, even with a heat gun, lithium grease, and excessive amounts of effort and trying to make an adaptor.
Eventually just ended up using 3/8 for the line and using a lot of overlap and multiple hose clamps on the hard line (the slotted kind, not the FI type that catch on themselves) and that stopped any leaks.
In terms of the rubber block, we had issues with that as well. For the vent line, I just left it and replaced the hose going to the T. The other lines just took a lot of white lithium grease and consistent pressure to get it through. When we removed the 5/16 line and replaced it with the 3/8, though, I just avoided the rubber squeezing all together and just ran it through the hole in the crossmember right next to it.
....man, this whole job was a PITA, though.
For all of you who have trouble with the hoses going through the rubber block... You can pull the block out with the hoses. It's open on one end and you fold it open. You can then place it on the lines where it should be and wrap it with tape. (factory did this) Then you feed the lines and the block back into place.
Nelliebelle7 is offline
post #47 of 72 Old 11-08-2013, 07:49 PM
dukeryder
Originally Posted by Mean Max View Post
Ok so I'm replying here for future reference for anyone who did a search like I did and came up with 1/4" tubing for the fuel lines.
On the 1995 (late 96 build date), YJ has 5/16 and 7/16" fuel line (well mine does anyway). Just one of those stupid YJ things where different years can have completely different parts.
dukeryder is offline
post #48 of 72 Old 11-08-2013, 07:51 PM
napaguy
7/16" fuel line? I have never heard of such a thing?
napaguy is offline
post #49 of 72 Old 11-09-2013, 05:01 AM
CrawlingForward
Mine is a 95 and mine were 5/16 and 3/8 as stated.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #50 of 72 Old 11-09-2013, 03:31 PM
Nelliebelle7
Yeah, me too. 5/16 and 3/8. Something else that may help a little, I eliminated that short hard line that goes to the "special" hose before the fuel filter. Ran the hose right from the tank to the filter.
post #51 of 72 Old 11-09-2013, 08:55 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
This seems like a good idea to me, I like it.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #52 of 72 Old 11-10-2013, 10:37 PM
dukeryder
I should have done this! I ended up buying the special Mopar 90* line, this option would've been much cheaper and easier too.
Mine most definitely had 7/16" line (I used 3/8 as the replacement). The crazy thing is that the return line hardline is of larger diameter than the main line, which is opposite of what's coming from the fuel pump (3/8" supply, 5/16 return). My guess is that someone once upon a time replaced the fuel pump and used the 7/16" line.
I swear this fuel tank R&R was the biggest pain in the @$$ job I've done to date on the YJ. That includes tearing the transfer case apart TWICE! (once to replace shift fork pads, once for SYE install).
post #53 of 72 Old 11-11-2013, 06:46 AM
Nelliebelle7
The good thing is that you won't have to do it again for a long time. Fingers crossed!
post #54 of 72 Old 08-18-2014, 02:11 AM
fantomas
Thanks for this write up! Just replaced the skid plate over the last week. A few helpful pointers I have for everyone: The fuel line is cheap enough that if you're going to drop the tank for any reason, buy 3' each of 5/16, 3/8 and 1/4" and proper fuel line clamps. Someone else said 2' was enough, but it is NOT (well it is, but the factory hoses were nearly 3'). We used 2' of each on the advice here and it was a tight fit getting everything connected because the tank had to be raised quite a bit.
We dropped the tank to replace the skid plate on Wednesday. Swapped the plate out within 3 hours with no real issues. Finally yesterday I went to drive it for the first time and the fuel hose must have dry rotted to the point that it leaked because we messed around with it. So we had to drop the tank again and replaced all three hoses. I have a late model '95 and got away with using 5/16" for the supply and return. The 3/8" would not fit in the block when we tried to get it back through the cross member. The gas tank connection is definitely 3/8" but we had no problem getting the 5/16" hose on.
Make sure the supply line is rated for fuel injection systems. The vent doesn't need to be, and I don't believe the return is under any sort of pressure either.
fantomas is offline
post #55 of 72 Old 08-18-2014, 10:45 PM
TomYJ
When I dropped my tank to change the pump, I took the tank to a local radiator shop to have it cleaned out - nothing like ruining a new pump with debris. I also changed the fuel filter and all the rubber hoses on top of the tank...found a vacuum line that was completely smashed from previous time the tank was installed.
TomYJ is offline
post #56 of 72 Old 02-21-2015, 06:21 PM
Mambo_Dave
Mean Max - thank you SO MUCH for this write up. I referenced this thread early this morning before heading out to Morris 4x4 and NAPA for the parts. The sizes and locations of the fuel line and vent lines were especially helpful.
Did the 20-gallon mod, replaced bad vent hoses, and fixed a big problem inside of the tank. Hopefully tomorrow I'll be able to fill the tank up to 20 gallons. The Warrior fuel tank skid plate was good enough for my needs, and was certainly heavier than the metal on the OEM skid plate (before it all rusted away).
I drilled four holes at the bottom of the Warrior skid plate, one for each low channel, to allow better draining of water that gets up in there. I then prepped and painted those holes.
Feeling good that my theory as to my fuel pump running at 100%, 100% of the time, seemed to pan out, and I think I have it fixed now.
I thought this would be a two-day event due to rain in the forecast, but it ended up raining elsewhere, and was a beautiful day to buy the parts at Morris 4x4 and NAPA, get them home, spend all day doing the jobs, and finishing in that same day. The sun felt great - and I'm now exhausted.
Mambo_Dave is offline
post #57 of 72 Old 02-21-2015, 08:22 PM
linusb
I've had to drop my tank too many times. It's a pain in the butt. I have a 8.8 and getting the assembly between the tub and the larger pumpkin is a challenge. I've learned to jack the jeep by the rear bumper a few inches to give additional clearance between the tub and the axle. With the 8.8 Id say it's a necessity and would make the job easier with the factory axle too Im sure. I've done the job alone every time and getting the assembly up into its spot is a challenge! B
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #58 of 72 Old 02-21-2015, 09:09 PM
Que89YJ
You should include relocating the ground with it too! Great write up.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #59 of 72 Old 02-22-2015, 05:30 AM
Mambo_Dave
What's up the with the ground? I missed that part.
post #60 of 72 Old 02-22-2015, 08:23 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I've had dozens and dozens of Jeep tanks out. Never had a YJ tank with a separate ground, but there is a ground wire in the sending unit harness.
Max
Mean Max is offline
YJ Fuel Tank Removal Problem Matt53 YJ Wrangler Technical Forum 8 11-04-2009 08:22 AM
Fuel leaks from top of fuel tank on cool mornings.....why? jeepdrvr69 YJ Wrangler Technical Forum 4 06-29-2009 11:57 PM
Need help with fuel tank removal? nickstix YJ Wrangler Technical Forum 4 04-08-2009 10:10 AM
Major vacume in fuel tank causing fuel to spill out bigredcherokee YJ Wrangler Technical Forum 2 09-28-2008 02:35 PM
Gas tank skid that requires no tank removal Thunderstrike TJ Wrangler Technical Forum 27 01-08-2006 11:41 PM
