How to - Fuel tank removal - Page 3 - JeepForum.com
post #31 of 72 Old 12-04-2010, 03:35 AM
USAJeep
fuel tank
I'm getting ready to pull my fuel tank for some frame repairs. Since the lines at the top of the tank will be removed once it's lowered, is it still necessary to ?
"I removed the fuel delivery & return lines from the hard lines located at the crossmember above the rear axle, on the driver's side. The tank vent line is also attached here as well."
Thanks in advance!
USAJeep is offline
post #32 of 72 Old 12-04-2010, 11:26 AM
Opihi59
from here it gets rough
Opihi59's Avatar
You get a bit more "play" that way with being able to lower the tank assembly. Honestly speaking, just mark them with tape (so you don't get them switched) and CUT them. This is the time to replace your soft lines with new high pressure fuel line. You can get this at most parts stores, comes on a reel, and they sell it by the foot. You need to make sure you specifically get the high pressure line for fuel injected systems.
Welcome to the forum.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #33 of 72 Old 12-05-2010, 04:52 AM
USAJeep
Thanks for the response and welcome!
USAJeep is offline
post #34 of 72 Old 12-09-2010, 09:30 AM
CrawlingForward
I'm also dropping the tank to replace the soft lines this weekend (they were so dry rotten that they started leaking fuel).
Edit: These are what I found after doing the job.
Vent --> T fitting = 1/4" (2 feet)
T fitting --> Hard line = 3/16" (2 feet)
Fuel delivery = Tank side: 3/8" Hardline side: 5/16" (2 feet)
return hoses = 5/16" (2 feet)
Could someone please confirm this or correct me, please?
Originally Posted by hdsport View Post
The fuel line that I replaced was the rubber line, about 10 inches long, with a plastic connector at each end. One end snaps onto the fuel filter assy on the module package in the tank, the other end snaps onto a connector on the fuel line to the front. I believe that one problem that I had was that I did not FULLY snap one end of this connector COMPLETELY onto the mating fuel line, possibly resulting in a slow leak under the pressure of the fuel pump.
So, problem solved and I don't have to take the tank down again.
Hope this was a help to you.
Also, isn't the TJ fittings different than our YJs? I think you guys have duck bill clips, so that wouldn't have the person asking the sizes.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
Last edited by CrawlingForward; 12-13-2010 at 08:28 AM. Reason: Did job, updating for posterity
CrawlingForward is offline
post #35 of 72 Old 12-09-2010, 10:08 AM
USAJeep
The lengths you have listed should be enough.
On mine the supply line is 3/8" and return line is 5/16.
Also.. specific to what I found, the sender/pump plate gasket is leaking and since I want to do the 20gal mod I'll be replacing the top gasket and grommets.
USAJeep is offline
post #36 of 72 Old 12-09-2010, 10:13 AM
CrawlingForward
Thanks! Wow, gatta love 4 different hose sizes in such a small area, ha ha.
post #37 of 72 Old 12-09-2010, 11:54 AM
MJDriver
MJDriver's Avatar
I could only find 1/4 line at Kragen or Pep Boys. It was the only one rated at 50 PSI. Had one helluva time getting them on, they barely fit with enough room to attach the hose clamps to the hard lines. Ugh.
Is anyone replacing or using the rubber cover that holds the lines as they run throught the body work, just above the hard lines. I may have a bend in the metal (can't tell) but once I took out the old lines, I could not get new lines through there. I got one line in, then nothing else. They fit side to side, but the surround, with the hoses, will not fit when pushing it in from the back to the front. I had to take out the rubber surround to get them back through.
Any suggestions?
Current - 1993 Wrangler 2.5 - mostly stock
Previous - 1989 Comanche Pioneer 4x4 Long Bed/Metric Ton Pkg
4.0, AT, D44 w/ Trak-Lok RIP
MJDriver is offline
post #38 of 72 Old 12-09-2010, 12:21 PM
USAJeep
The 1/4, 3/16" vent lines don't need to be pressure rated IMHO.
I haven't pulled my line out of that rubber block yet.. and that's why, didn't think I could get them back through.
Thought the body settled and tried jacking up right beside the rubber block.. didn't budge!
Interested in a solution as well
USAJeep is offline
post #39 of 72 Old 12-13-2010, 08:24 AM
CrawlingForward
Yeah, I forget who said it, but the supply line definitely is 3/8 on the tank side and 5/16 on the hard line side. Trying to use 5/16 to fit on both ends did *not* work, even with a heat gun, lithium grease, and excessive amounts of effort and trying to make an adaptor.
Eventually just ended up using 3/8 for the line and using a lot of overlap and multiple hose clamps on the hard line (the slotted kind, not the FI type that catch on themselves) and that stopped any leaks.
In terms of the rubber block, we had issues with that as well. For the vent line, I just left it and replaced the hose going to the T. The other lines just took a lot of white lithium grease and consistent pressure to get it through. When we removed the 5/16 line and replaced it with the 3/8, though, I just avoided the rubber squeezing all together and just ran it through the hole in the crossmember right next to it.
....man, this whole job was a PITA, though.
post #40 of 72 Old 12-13-2010, 01:27 PM
MJDriver
MJDriver's Avatar
In addition to the above (and I will try lithium grease next time) make sure you have lots of slack on the front side (engine side) of that damn dividing hole. My lines are stretched tight due to that $#@%ing hole, and that rubber block.
I will probably have to drop it again just to re-work that part.....and then find the original engineer for this section of the vehicle and put massive amounts of exlax in his bean burrito for not making it easier to get in there, or get the tank out.
MJDriver is offline
post #41 of 72 Old 07-19-2013, 05:18 AM
grandboost98
Bump for pic fix!
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #42 of 72 Old 09-16-2013, 06:30 PM
goroboto
Great thread - can you guys fix the photos when you get a chance?
goroboto is offline
post #43 of 72 Old 09-16-2013, 07:12 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I have so many pics on Photobucket that I'm exceeding my bandwidth.
I haven't had the extra $$ to upgrade yet, but I plan on doing it soon!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #44 of 72 Old 09-16-2013, 08:22 PM
lander2312
Jeep forum should host all your pics since your soo helpful to all of us.
lander2312 is offline
post #45 of 72 Old 09-16-2013, 08:28 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
That would be nice, but even if they did, moving them & fixing the links would be a nightmare.
Max
Mean Max is offline
YJ Fuel Tank Removal Problem Matt53 YJ Wrangler Technical Forum 8 11-04-2009 08:22 AM
Fuel leaks from top of fuel tank on cool mornings.....why? jeepdrvr69 YJ Wrangler Technical Forum 4 06-29-2009 11:57 PM
Need help with fuel tank removal? nickstix YJ Wrangler Technical Forum 4 04-08-2009 10:10 AM
Major vacume in fuel tank causing fuel to spill out bigredcherokee YJ Wrangler Technical Forum 2 09-28-2008 02:35 PM
Gas tank skid that requires no tank removal Thunderstrike TJ Wrangler Technical Forum 27 01-08-2006 11:41 PM
