How to - Fuel tank removal - Page 2 - JeepForum.com
post #16 of 72 Old 10-20-2010, 10:42 AM
bword
Thank you for this..I have a leak somewhere near my tank this will help when I try to take mine down.
Selling a Totaled XJ in Ct..PM me for details
bword is offline
post #17 of 72 Old 10-21-2010, 03:42 AM
RookieJeeper01
1987 YJ Wrangler
Great write up. I did the same thing recently, new warrior skid plate. I found it the cheapest at JC Whitney.
RookieJeeper01 is offline
post #18 of 72 Old 10-21-2010, 06:19 AM
hdsport
2008 WK
Don't mess with leaking gas....any electrical connection spark can toast your jeep.
I just did mine.....all new hoses, fuel line attachment (one with the clips on it) and fuel pump,filter assy, lock ring and gasket.
No more gas dripping and no more fumes.
Well worth the peace of mind and I don't have to breath gas fumes any more.
hdsport is offline
post #19 of 72 Old 10-21-2010, 07:36 AM
bword
you remember what size fuel line? rubber or metal??
bword is offline
post #20 of 72 Old 10-21-2010, 03:10 PM
hdsport
2008 WK
The fuel line that I replaced was the rubber line, about 10 inches long, with a plastic connector at each end. One end snaps onto the fuel filter assy on the module package in the tank, the other end snaps onto a connector on the fuel line to the front. I believe that one problem that I had was that I did not FULLY snap one end of this connector COMPLETELY onto the mating fuel line, possibly resulting in a slow leak under the pressure of the fuel pump.
So, problem solved and I don't have to take the tank down again.
Hope this was a help to you.
hdsport is offline
post #21 of 72 Old 10-21-2010, 03:41 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Max, is that Warrior Product skid strong enough to hold up in the rocks? Friends have told me I need a gas tank skid before trying the Rubicon or Moab.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #22 of 72 Old 10-22-2010, 07:22 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
It's pretty near twice the thickness as the stock one, so it will easily outperform the OE skid, but there are heavier duty skids available I believe.
Are your friends currently using heavier duty skids?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #23 of 72 Old 10-22-2010, 10:33 AM
Mobile_Homie
Desert Rat
Max
I will have to check, but the way I understand it you need to be able to scrape along the rocks on those trails.
Mark
post #24 of 72 Old 10-22-2010, 11:02 AM
Aahzmandius
Originally Posted by ThomasYJ View Post
BTW... Do you have any ideas on how to Patch/Seal the tank without having to buy a new one? I've got two lateral cracks in mine (hence the reason for dropping it) on the bottom rear left corner about an inch or two in length a piece.
Try this:
http://www.permatex.com/products/Aut...Repair_Kit.htm
Haven't tried the plastic one, the steel tank kit one works well.
Aahzmandius is offline
post #25 of 72 Old 11-04-2010, 06:54 AM
WSNJeep
Great Post! I just did this last weekend, but am running into a bit of a head scratcher. Those two white outlets on either side on the top of the tank that are attached to hoses which come to a "T"....what are those outlets called? I need to replace them and whatever grommets are needed but cant locate them anywhere (partially because I cant accurately describe them!) My previous owner decided just to use gasket sealant or some kind of goo to attach these...not good
Any Ideas? Thanks in advance!! :-)
WSNJeep is offline
post #26 of 72 Old 11-04-2010, 09:44 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Scroll to the bottom of this page for the MTS Company's YJ tank parts and you'll find the grommets you need. They're $5.95 each if I remember correctly. Ask for Mike, he handled my order a week or two ago & was very helpful!
Max
Mean Max is offline
post #27 of 72 Old 11-05-2010, 05:57 AM
WSNJeep
Thanks Max....I lucked out last night and was able to find what I needed. The parts I was looking for are the rollover valves!! I was able to pick up new ones on Ebay. Hopefully that will take care of them!
Thanks again!!
WSNJeep is offline
post #28 of 72 Old 11-24-2010, 01:11 PM
MattyMcF90
Hey Guys, great thread!
I have been battling a fuel issue with my 1990 YJ for awhile now. The two guys that stopped today when I was stranded in the grocery store parking lot may discovered I was looking at the wrong thing..
My question is: Is there a fuel pump/screen/rollover valve/sending unit(not sure what this is), or anything that would block or allow air into my fuel delivery to my mechanical fuel pump on the engine? I have a fuel issue (that until today I thought was just at my carb), that keeps making my YJ die when it is warm.. but runs when it is cold.
For anyone interested.. you can see the thread by seraching
"Weber Carburetor - Runs when hot or old... but no fuel when warm."
MattyMcF90 is offline
post #29 of 72 Old 11-24-2010, 01:28 PM
Que89YJ
There is a screen in the fuel tank at the pickup. You should check your pressure before you go to drop the tank though. The rollover vavle doesnt stop fuel flow, but if tyou look at the rear body mounts some people have had the fuel line pinched in the rear from the the body mounts going bad and not giving enough clearance on the fuel line. Is this write up added to the list? Great refrence.
Que89YJ is offline
post #30 of 72 Old 11-24-2010, 01:41 PM
hdsport
2008 WK
Don't really know the size. This is a factory item, not like the old days when you bought fuel line by the size and length. This is made with special connectors at each end, etc.
Hope this is a help..................
hdsport is offline
YJ Fuel Tank Removal Problem Matt53 YJ Wrangler Technical Forum 8 11-04-2009 08:22 AM
Fuel leaks from top of fuel tank on cool mornings.....why? jeepdrvr69 YJ Wrangler Technical Forum 4 06-29-2009 11:57 PM
Need help with fuel tank removal? nickstix YJ Wrangler Technical Forum 4 04-08-2009 10:10 AM
Major vacume in fuel tank causing fuel to spill out bigredcherokee YJ Wrangler Technical Forum 2 09-28-2008 02:35 PM
Gas tank skid that requires no tank removal Thunderstrike TJ Wrangler Technical Forum 27 01-08-2006 11:41 PM
