how to fix weather stripping - JeepForum.com
post #1 of 7 Old 07-04-2013, 05:57 PM Thread Starter
metalhead
2011 WK
I have a 94 wrangler with full doors. I have attempted to replace the rubber weatherstripping that goes around the door. The first set I bought was way too big. I contacted quadratec where I bought it from and they sent me out a new set. The drivers side door weatherstripping fit much better but the passenger door weatherstripping was still too big. I have read somewhere about cutting it to fit and using special weatherstripping glue to glue it together. Has anyone done this and can kind of walk me through it. It would be cheaper to cut it down then pay shipping to sent it back.
metalhead is offline
post #2 of 7 Old 07-05-2013, 01:44 PM
czjeeper
The new weather strip will appear too "big" because the oem was so bad.
I replaced all of mine last winter and had the same issue.
I think cutting the weather strip would be foolish.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #3 of 7 Old 07-05-2013, 10:07 PM
jred
It depends on if he means too big=too fat or too big=too long. If it's too long, I would think you could trim it at the corners and glue it back together.
jred is offline
post #4 of 7 Old 07-05-2013, 10:32 PM
SeanB95YJ
as for the adhesive, yes 3M (and I think Permatex too) makes a weatherstrip adhesive... most auto parts stores should have one of them in stock... either in a tube like you put in a caulk gun, and/or a smaller squeeze tube like toothpaste
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #5 of 7 Old 07-06-2013, 02:11 AM
90DesertTanYJ
What Sean said. 3M makes a good product and iy comes in yellow or black. Since the yellow looks like elephant snot, I would choose the black. Follow directions, make sure the talcum like powder on the strip has been completely removed before attempting to glue the strip down.
90DesertTanYJ is offline
post #6 of 7 Old 07-06-2013, 01:51 PM Thread Starter
metalhead
2011 WK
To clarify it is too long. I have to bunch it up in a corner to get it to fit and then the door won't close right. I did email quadratec to see what to do.
post #7 of 7 Old 07-06-2013, 02:34 PM
andrew2641
I have the same problem. I have yet to cut it to close better its atleast 2-3 too long. The push pegs are spaced correctly and the corners fit well. My problem showed up around the door latch area.
andrew2641 is offline
