#1 | |
How fast am I really going
Well now that I got my 33's on and re-geared to 4:88 I have no idea how fast I going down the freeway. How hard is it to change out the speed-o gear to get it back to read correct ?
Not here for a long time, were here for a good time |
#2 | |
Jello Puddin'
Changing the speedo gear is at most a 5 minute job. The hardest part about it is seperating the $80 from your wallet. Here's a chart... http://www.jeep4x4center.com/jeep-speedometer-gears/index.htm
Looks like you'll need the 41 tooth gear. http://www.jeep4x4center.com/jeep-speedometer-gears/index.htm#41 Oh yeh, you'll need the short shaft one. Here's a couple of quick little write ups. http://www.nagca.com/grandtech/speedometerregearing.htm and http://www.eriejeeppeople.com/Jeep_tech/misc_instructions/SpeedoGears.htm
#3 |
Injanir
I'm planning on getting a new speedo gear after my 33's. I just regeared to 4.10's and I am still running 31's. So for now, I was driving on the highway behind my gf and just called her to ask how fast she was going. Now I just subtract 15 mph off the speedometer.
Lou I have a jeep...and it is modified...I win. My Dumb Ole' Build Thread Warn M8000 Rebuild Adventure University of Georgia |
#4 |
I heart bacon and pie
Your speedo will not be off by a constant amount. It will be off by a percentage. The faster you go the greater the error in actual vs indicated speed. So at 30 mph actual speed your indicated speed will not be off by 15mph.
#5 |
Timatoe, why did I already know it was going to cost me more $$ than I thought ti would. Welcome to the world of Jeep ownership. Thanks
#6 | |
Jello Puddin'
Check eBay too, I've bought two (used) gears in the past on there for well under $20 each.
#7 |
Thanks will do, thats more like I want to spend
#8 |
Borrow someones gps and note the speeds on your speedometer verses the gps at various speeds.
91 Wrangler 4.0 5sp 8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows |
#9 |
Injanir
Yeah, I thought it would not be constant since its not linear with gearing involved. I think I remember reading about it on another thread too. I just suggested it because it was quick and its a little easier than taking a percentage for every speed.
#10 | |
#11 | |
Injanir
#12 |
I was wondering the same thing, what do they come out of
#13 |
time the measured mile on the interstate. This will tell you how far you are off, both from gearing/tires as well as speedo innaccuracy. THEN calculate your new gear from that real world number.
#14 |
X2 on the GPS, this is the easy way!
'89, 4.2, NUTTERED, Team Rush, 4" lift, 1"BL, 1"MML, Flat belly skid, SYE, CV Driveshaft,
35 x 12.50s, XRC8, 150w KC's, Herculined, Tauras Elec Fan, Dual Batteries, 1" shackles & Soft Top for the summer, TJ flares. |
#15 |
The speedo gears were identical in any of the jeeps I was grabbing them from that had a np231. All of the cheokees, and even some dodges that ran a 231. I had to go thru about a dozen to find the right tooth count for mine, but since it only takes a minute to pull the bolt and check the color of the speedo gear, then read the number to verify, it was a 20 minute process to find the right one. The clocking ring even has numbers printed on it so when you go to install, you just turn the notch to the right set of numbers (ie 27-35 tooth) and tighten up the bolt.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
