How far does your choke plate go? - JeepForum.com
post #1 of 1 Old 12-29-2008, 03:13 PM Thread Starter
Stauffeneker
2014 JK Wrangler
Hi all,
I installed a rebuilt Carter BBD carb on my 89 YJ 4.2 and I just cannot get it to idle or run right. I have adjusted the idle a million times, set the timing many time and I still get a mostly rich setting (black smoke, black plugs) that bogs and dies. It got me thinking of the choke plate. My WOT choke plate position is only at a little better than 45 degree angle. Should it be at a full 90 degrees when running hot and open? If so, how do I adjust the choke plate to do it? It's got that electric choke thing on the carb. Any ideas? I need to get it running soon for the nasty swedish inspection so I'm getting a little worried. Thanks. This site has got me through a load of newbie problems.
Stauffeneker is offline
Can I convert a weber 32/36 electric choke to manual choke? jake42 YJ Wrangler Technical Forum 2 07-19-2011 06:14 PM
89 Choke plate Bravo181 YJ Wrangler Technical Forum 4 02-06-2010 06:55 PM
Weber Electric choke to Manual Choke? smitkev2 YJ Wrangler Technical Forum 7 10-03-2009 09:12 AM
How do I get 90 degree choke plate? Stauffeneker YJ Wrangler Technical Forum 0 01-07-2009 05:26 AM
Weber 34 - choke plate won't open?? defmornahan YJ Wrangler Technical Forum 8 12-01-2008 10:05 PM
