How far can you stretch WB without any "major" modifications? - JeepForum.com
post #1 of 4 Old 03-22-2011, 12:48 PM Thread Starter
TheNewbie
How far can you stretch wheel base without any "major" modifications? I was thinking about relocating the shackle hangers to the bumpers. I just have a few questions.
1) How far can you stretch it in the rear without having to worry about the gas tank?
2) How far can you stretch it in the front without having to modify anything like the steering?
3) Is there anything else that will have to be modified besides the gas tank and steering components?
4) Can I just relocate the the shackle hanger and keep the frame side mounts in the same place (with the same springs)? Or do I have to move them too?
5) How much should I stretch it to make it worth it? Is a couple extra inches even worth it?
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #2 of 4 Old 03-22-2011, 01:19 PM
grandboost98
from what ive read, you cant move either very far without doing the modifications youve said. and you would have to move the frame side mounts too if your using the same spring, otherwise you can leave them and use waggy springs
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 4 Old 03-22-2011, 01:43 PM Thread Starter
TheNewbie
I should also mention that I have tube fenders up front so I could stretch as far forward as needed without hitting any metal. And I have TJ flares in the rear that I mounted a bit further back than normal so i have an extra 2" back there.
post #4 of 4 Old 03-22-2011, 02:31 PM
ssyj94
1" or less depending on what axle you have.
You can get 2-3" with stock steering.
DRIVESHAFTS!!!
Ofcourse you have to move them too unless you use longer springs.
It all depends on what size tires your goin to run.
My build:
ssyj94 is offline
LJ Build "Sylvia" another stretch on tons, COs, Hemi Swap-- EVENTUALLY VecoPlan TJ Wrangler Technical Forum 322 11-18-2013 09:20 AM
Rubicon Express 2.5" Extreme-Duty Rear Radius Arm 4" Stretch System BRICKTOP2 TJ Wrangler Technical Forum 6 02-20-2010 10:10 AM
YJ Easy 1.5"-2" Rear Stretch- Perch Redrill supersteez YJ Wrangler Technical Forum 10 01-07-2010 03:34 PM
Clayton's long arm and 5" stretch or the double triangulated with the stretch? Haz-Mat TJ Wrangler Technical Forum 14 08-14-2009 07:44 PM
"X" or "Sahara" what are teh major differences 88xj JK Wrangler Technical Forum 21 09-10-2007 01:13 PM
