How do you remove the rear brake distribution block off rear? - JeepForum.com
post #1 of 7 Old 11-25-2008, 09:40 PM Thread Starter
01blackws6
Does it just twist off or pop off or what? I need to change my brake lines off my old rear to this new one and am trying to figure out how to remove the block off of the rear end, the guy I bought the new rear off of cut the rubber flexible line off of the distribution block.
1994 YJ 2.5l. RUST BUCKET!
1" daystar BL.
01blackws6 is offline
post #2 of 7 Old 11-25-2008, 09:42 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The vent line (rubber line part) unscrews from the axle tube. Just remove it & the block will come right off.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 7 Old 11-25-2008, 09:47 PM
JERSEY5.0YJ
1987 YJ Wrangler
the block is held down with a breather which is threaded into the axle tube
if you look at it close you can see where you would be able to put a wrench and unbolt it
JERSEY5.0YJ is offline
post #4 of 7 Old 11-25-2008, 09:56 PM Thread Starter
01blackws6
Ok so pull the rubber vend hose off then unscrew the nipple from the axle housing and the block should come off?
1" daystar BL.
post #5 of 7 Old 11-25-2008, 10:05 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, exactly.
Mean Max is offline
post #6 of 7 Old 11-25-2008, 10:28 PM Thread Starter
01blackws6
Cool thank you!
1" daystar BL.
post #7 of 7 Old 11-25-2008, 10:30 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Welcome!
Mean Max is offline
How to remove rear brake line clip? 88TNSahara YJ Wrangler Technical Forum 5 12-15-2009 10:30 PM
How does the rear brake junction block attached? Bren Gun TJ Wrangler Technical Forum 11 09-18-2009 04:47 PM
Is Brake distribution block for D44 same as D35? roundlitefan TJ Wrangler Technical Forum 4 08-30-2009 06:26 PM
Cannot remove rear brake rotor... thejafe TJ Wrangler Technical Forum 4 02-15-2009 05:28 PM
Custom Power Distribution Block Rescue1 JK Wrangler Technical Forum 8 10-03-2008 02:48 AM
