How do you remove the parking brake pedal assembly? - JeepForum.com
post #1 of 9 Old 07-01-2008, 11:12 AM Thread Starter
veritas4156
1991 MJ Comanche
Hey guys, my parking brake lever assembly is shot, the ratcheting mechanism is dead, so I'm going to rig something up out of a toyota pickup because it looks simple enough to install. I know there is the one bolt at the front of the pedal assembly but where else is it being held on? Feels like its riveted towards the back but my computer is right on the back of that so I dont want to drill it out. Any ideas or is it not really riveted?
veritas4156 is offline
post #2 of 9 Old 07-01-2008, 11:33 AM
Jim93YJ
Jim93YJ's Avatar
Hey, see if your jeep has the recall on the parking brake mechanism. If it does then the dealership will replace the whole assembly for free. Type in your VIN and www.jeep.com and it will let you know if there is a recall for your jeep.
93YJ 4.8L Vortec,AX15,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 33" BFG KM2 T/A's with MT Classic II Wheels, Herculined Inside, Electric Fan, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bushwacker Extended Flat Fender Flares,AMSoil/Redline In Everything and the List Goes On....
AND...
88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater.
Jim93YJ is offline
post #3 of 9 Old 07-01-2008, 12:37 PM
MooJr
Just did this to my 94, only cost me a couple hours on a saturday at the dealership.
Your local neighborhood Noob - Nate
MooJr is offline
post #4 of 9 Old 07-01-2008, 01:09 PM
idaholtby
Just call the dealership and give them your V.I.N. to see if it needs or has had the recall. Unfortunately, the jeep.com site does not go further back than a 1992 model.
idaholtby is offline
post #5 of 9 Old 07-01-2008, 01:40 PM
Exparrot
Exparrot's Avatar
If your 88 is like my 93, there's one bolt underneath the dash holding the assembly up (you got that one) and two bolts going through the firewall. Open the hood and you'll see them near the clutch master cylinder and the ECU.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #6 of 9 Old 07-01-2008, 01:54 PM
geekboy31
just did mine a few weeks ago......just bought the jeep looked up the vin had the recall work done...only a few hours
geekboy31 is offline
post #7 of 9 Old 07-01-2008, 02:11 PM
Lee3333
My parking brake ratchet was shot when I bought my jeep a couple of months ago. I picked up a new one from someone on the forum and just finished putting it in a few minutes ago. It is just 3 bolts like Exparrot said, and a wire plug for the idiot light. But, remember you have to loosen the cable to get it out. There are 2 1/2 inch nuts on the threaded cable cover on the drivers side in front of the back tire. It goes into a distribution plate. You have to remove the end nut, then loosen the other one all the way to allow enough slack to get the cable out of the parking brake ratchet assembly. When reinstalling, I tightened the nut until the car doesnt move with the parking brake engaged and the car is in gear. I was afraid of making it too tight and having the brake pads rubbing.
I did call about the recall but mine was apparntly already fixed (then broke again).
Lee3333 is offline
post #8 of 9 Old 07-01-2008, 07:09 PM
azgurney
This does not apply to your 88, but if you have a 91 up 4.0 there is a ground wire attached to one of the mounting bolts. It is the ground for the fuel pump and fuel gage. If you forget it the fuel gage will stay pegged out full and the fuel pump will not run.
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
post #9 of 9 Old 03-15-2010, 07:42 PM
cvisinho
That confirms my assumption of that ground meaning something when the truck wouldnt start without the ground cable connected
cvisinho is offline
YJ 1989 Emergency brake pedal assembly Gatorgirl YJ Wrangler Technical Forum 14 08-07-2009 06:43 PM
parking brake assembly recall YJ_95 YJ Wrangler Technical Forum 19 05-07-2008 11:34 AM
Parking brake pedal assembly veritas4156 YJ Wrangler Technical Forum 12 05-06-2008 07:58 PM
Brake Pedal Assembly evster5 YJ Wrangler Technical Forum 4 01-02-2006 01:45 AM
TJ pedal assembly (brake, clutch. gas) on a CJ? apachetech TJ Wrangler Technical Forum 0 08-12-2004 06:27 PM
