How do you get this little guy out? - JeepForum.com
post #1 of 18 Old 01-19-2013, 08:53 AM Thread Starter
cbl600r
I can't get anything in there to get that torx head bolt out. Any suggestions?
cbl600r is offline
post #2 of 18 Old 01-19-2013, 08:59 AM
schaef89
When I did this on mine I took channel locks and bent the fender metal back until I could get a socket in there
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #3 of 18 Old 01-19-2013, 09:00 AM
youngjeepr
Go buy a smaller torx Socket... It looks like you have 3-4" of room... Or is that just the angle of the picture
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #4 of 18 Old 01-19-2013, 09:03 AM Thread Starter
cbl600r
There is about an inch of Clarence right above the head. The wheel well is in the way... The torx socket I have is about a inch tall and there is no room for the rachet
cbl600r is offline
post #5 of 18 Old 01-19-2013, 09:11 AM
schaef89
Try what I said above. Worked for me
schaef89 is offline
post #6 of 18 Old 01-19-2013, 09:13 AM
youngjeepr
Try what shaef89 said or try to get a universal joint on the socket
post #7 of 18 Old 01-19-2013, 09:18 AM
CrawlingForward
Universal joint or I just shoved things aside and used a massive extension.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #8 of 18 Old 01-19-2013, 09:23 AM
pasinbuy
Try using a extension on the socket. 6 inch should clear it for you.
pasinbuy is offline
post #9 of 18 Old 01-19-2013, 09:27 AM
SeanB95YJ
I couldn't get them either... I drilled until the head popped off, tacked an extension piece of sheetmetal to move the bracket hole a little farther away from the line, then used a self-tapping bolt in a new hole I drilled in the frame. then relocated the hole and used a self-tapping hex head
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #10 of 18 Old 01-19-2013, 10:10 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I get them all the time from the top and using about 15" of extensions and an impact gun. It allows you to keep constant pressure on it without stripping. Allah help you if you strip a torx bolt.
Luck Favours The Prepared
Anticanman is offline
post #11 of 18 Old 01-19-2013, 04:04 PM
NHfireLJ
NHfireLJ's Avatar
Grinder!!!!
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #12 of 18 Old 01-19-2013, 04:32 PM Thread Starter
cbl600r
Ok I going to try and find a shorter torx bit and use the impact. I will follow up
cbl600r is offline
post #13 of 18 Old 01-19-2013, 05:30 PM
jonmaclean19
i used a pry bar. it flexed just enough and didnt cause any damage.
jonmaclean19 is offline
post #14 of 18 Old 01-19-2013, 05:50 PM
uhohthe50
I got mine out no problem with a bunch of extensions. You should be able to come in through the engine bay
My 1990 YJ Build Thread: http://www.jeepforum.com/forum/f22/might-well-start-build-thread-now-my-1990-yj-1291174/
uhohthe50 is offline
post #15 of 18 Old 01-19-2013, 05:54 PM
Northinger
I got mine out no problem with just a socket wrench..
Northinger is offline
