How do you fix a oversized hole in sheetmetal ? - JeepForum.com
post #1 of 11 Old 03-08-2014, 04:56 PM Thread Starter
JohnW63
After years of putting up with a loose soft top attachment groove on top of the windshield, I finally bought the rivet kit that replaces the stripped out holes with stainless rivets and machine screws. All went well but one hole. The last hole on one side, where they mention you need to enlarge a hidden hole below the top hole you just drilled out got slightly ovaled, as I had to angle the bit to open up the inner hole. The two did not line up well, like they did in the driver's side. Now , this one hole is too big for the rivet to hold in.
What are my options ?
If I knew how to weld, I guess I could fill in a bit of the hole and file it out to a proper fit, but I haven't ever welded sheet metal and I have no tools for that. I might be able to take it somewhere to have it done.
What about gluing it in place with something like JB Weld ?
Has anyone run into this issue ?
JohnW63 is offline
post #2 of 11 Old 03-08-2014, 05:05 PM
debord97
If it was mine I would just weld it. I'm sure jb weld would hold it just fine though. I've used jb weld to put all kinds if stuff back together before including a mirror bracket on a 99 firebird.
debord97 is offline
post #3 of 11 Old 03-08-2014, 05:16 PM
jbolty
jbolty's Avatar
I would cut a piece of tin long enough to cover the hole, glue it in place, put the channel over it then then put a screw or rivet on either side of the damaged hole.
jbolty is offline
post #4 of 11 Old 03-08-2014, 05:48 PM
RockWoRM
RockWoRM's Avatar
They make different size rivets. If you're using the smaller ones, then you could size up possibly.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 11 Old 03-08-2014, 06:33 PM
Mark05059
there are these things called u-nuts.. they work awesome for that issue.
http://www.itwcip.com/products/u-nuts/
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 11 Old 03-08-2014, 07:20 PM Thread Starter
JohnW63
I like the U-nut idea, but there is no edge to slide it on. The hole is on the top corner of the windshield frame.
I suppose the metal over the hole would work. Since the fancy repair kit threaded rivets stick up above the level of the metal, I could use a strip of something the same thickness and attach it over the hole and then use a normal sheet metal screw to hold that one corner down.
If I could weld it and reshape the hole so the spare rivet would fit, I would take that option.
The JB weld option might be a "can't hurt to try " method. I'd have to figure out how to hold it in the hole at the right angle, until it dries. Will that stuff stand up to the tension the top will put on that corner of the channel ?
JohnW63 is offline
post #7 of 11 Old 03-08-2014, 09:01 PM
Old4X
1990 CJ7
How about a riv-nut and a machine screw?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 11 Old 03-08-2014, 09:30 PM Thread Starter
JohnW63
A rvinut is exactly what the kit came with. If I could find a bigger one, that has the same thread it would work. Not sure where to get them. I've only ever seen them in the repair kit at the Jeep parts web sites.
JohnW63 is offline
post #9 of 11 Old 03-08-2014, 09:46 PM
Old4X
1990 CJ7
\They come in many sizes. The larger ones take bigger screws, but it is simple to mod it to any size screw you want
Old4X is offline
post #10 of 11 Old 03-08-2014, 10:07 PM Thread Starter
JohnW63
I think the hole for the ones in the kit is 1/2". I've started looking for some.
JohnW63 is offline
post #11 of 11 Old 03-08-2014, 10:07 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
There are small washers (backers) that can be used with rivets. Can one be worked into the hole and glued in temporarily then riveted after it sets?
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
