How Do You Fix A Broken Turn Signal/wiper Lever - Page 2 - JeepForum.com
post #16 of 18 Old 10-31-2014, 05:08 PM
Quinzy13
Mine finally broke clean off so that my wipers are stuck on, the metal rod is still sticking out so I can use the turn signals, but all the wires are shot to hell so I'm just trying to find a part that will work. I have a 91 JC. Evidently there isn't any 91 parts floating around. How new do you think I can go on parts before they don't fit? I haven't taken the steering wheel off yet to see what the insides look like.
Quinzy13 is offline
post #17 of 18 Old 10-31-2014, 05:14 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Originally Posted by ski74d3 View Post
i just drilled mine with a smaller diameter drill bit and screwed the coordinating tap in and the little broken piece will pull right out then just install your new one by pushin it straight end i go mine at a local junkyard out of a xj they just pull out.
Good Luck
THIS^ you have to be patient and drill in the center, but it can be done. Be very careful with the hardened steel tap, if it breaks off in there, it's the full steering wheel removal to get it out.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #18 of 18 Old 10-31-2014, 05:15 PM
Luuca
Luuca's Avatar
The switch, lever, and wiring from a 90s model XJ (as common as gravel in the pick-a-part yards) is a direct replacement. You'll need a steering wheel puller to remove the steering wheel and some sockets to drop the column down.
YJOTM Sept. 2017
Luuca is offline
Broken turn signal lever, Need to turn OFF hi-beams Tulsachokehold YJ Wrangler Technical Forum 16 12-10-2014 12:39 AM
Turn signal Lever broken? FlyersFan2009 TJ Wrangler Technical Forum 16 02-01-2012 02:04 PM
wiper/turn signal switch & lever garin3 YJ Wrangler Technical Forum 7 04-29-2009 01:23 PM
yj windshield wiper turn signal lever acat YJ Wrangler Technical Forum 7 06-28-2007 04:07 AM
wiper/turn signal lever StuckInMud94 YJ Wrangler Technical Forum 3 08-06-2005 10:49 AM
