How Do You Fix A Broken Turn Signal/wiper Lever - JeepForum.com
post #1 of 18 Old 08-24-2008, 12:29 AM Thread Starter
twokids
1983 CJ7
Is there anyway to fix a broken turn signal/wiper lever.I hit it with my knee and it broke clean off.I guess the metal piece on the inside has to turn for the wipers to work.I thought maybe crazy glue but thought I would toss it out to you guys first.
twokids is offline
post #2 of 18 Old 08-24-2008, 12:43 AM
aaronc88
sure it didnt just pull out.
If not then probaly would have to pick up a new one i would suppose.
My work
aaronc88 is offline
post #3 of 18 Old 08-24-2008, 01:02 AM Thread Starter
twokids
1983 CJ7
Can you replace just the lever????
twokids is offline
post #4 of 18 Old 08-24-2008, 01:17 AM
teejmcd
depends... if you didn't break any part of the switch then sure... if the metal is stuck in the switch like mine was then that sucks i had to take apart the whole thing to get the switch out to.. it takes a while to do and a lot of patents.... because i didn't have wipers, rain ex was my friend for a while
1994 yj. lifted 4 inches locked, loaded, and armored!
Member of CORE4X4.NET
teejmcd is offline
post #5 of 18 Old 08-24-2008, 10:04 AM Thread Starter
twokids
1983 CJ7
My metal rod broke,but I can still put it back in and get my blinkers to work,but not my wipers.I think the metal rod has to turn for my wiper to work.
twokids is offline
post #6 of 18 Old 08-24-2008, 10:48 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Go to autozone and rent the steering wheel puller and lock ring depressor. $30 but you get that money back when your done. Now follow this writeup and you can get to you switch and be back togeather in an hour or so. http://www.epiccomputer.com/dale/jee...tilt/tilt.html Yes that is for a CJ but it is the same GM column.
Your gonna need to get a new lever. dealer can do it for less than $20 ( I think) or go to a bone yard.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #7 of 18 Old 08-24-2008, 12:54 PM
laredo89
Yep, you can get the lever from the dealer for $18
laredo89 is offline
post #8 of 18 Old 08-24-2008, 02:21 PM Thread Starter
twokids
1983 CJ7
So I do have to take the steering wheel off.I think I might try my luck with crazy glue first.
twokids is offline
post #9 of 18 Old 08-24-2008, 03:03 PM
rustywrangler
Ok but at least check the link that I posted. It is not that hard. And with the rented pullers the wheel and lock ring literally come off in about 2 min.
post #10 of 18 Old 08-24-2008, 03:43 PM Thread Starter
twokids
1983 CJ7
Crazy glue did not work.It looks like I get to take off my steering wheel. thanks for the replies.
twokids is offline
post #11 of 18 Old 08-24-2008, 06:53 PM
yjcrawler
i broke mine off one night when i was mad and i changed mine this past week actually. i took the turn signal switches and the shroud piece off and the actual lever is just pushed in there. after you take the column apart you can use a punch and just push it out. ohh and a little L shaped piece of plastic will probley fall out, but this kinda sits over the little metal rod thing. this will probably make more sense once you take it apart.
Soon to be SOA with 14 Bolt SF rear, D44 front and 38's
Early YJ Club, Member # 33
yjcrawler is offline
post #12 of 18 Old 08-24-2008, 08:52 PM
ski74d3
i just drilled mine with a smaller diameter drill bit and screwed the coordinating tap in and the little broken piece will pull right out then just install your new one by pushin it straight end i go mine at a local junkyard out of a xj they just pull out.
Good Luck
ski74d3 is offline
post #13 of 18 Old 08-24-2008, 09:46 PM
Hambne
I used a small self tapping screw on the piece that was inside the sterring column and yanked it out with a pair of pliers. I have a 91 yj and bought the lener from the dealer for aroung $20. and pushed right in there. I dont know if it the same for a cj or not. good luck
Don't sweat the small stuff, and dont pet the sweaty stuff.
Hambne is offline
post #14 of 18 Old 11-11-2008, 02:20 PM
powder99
Lever must be in off position,so a screw extractor won't work.A self tapping sheet metal screw is the way to go.If you've got the lever in the right position it'll pop right out...
powder99 is offline
post #15 of 18 Old 12-16-2008, 01:59 PM
pitbullguiller
1987 YJ Wrangler
I just broke mine a month ago! Is there a part # for the lever? I have an 87 YJ... and I am planning on placing a new turn signal lever/with windshield controls.
pitbullguiller is offline
Broken turn signal lever, Need to turn OFF hi-beams Tulsachokehold YJ Wrangler Technical Forum 16 12-10-2014 01:39 AM
Turn signal Lever broken? FlyersFan2009 TJ Wrangler Technical Forum 16 02-01-2012 03:04 PM
wiper/turn signal switch & lever garin3 YJ Wrangler Technical Forum 7 04-29-2009 02:23 PM
yj windshield wiper turn signal lever acat YJ Wrangler Technical Forum 7 06-28-2007 05:07 AM
wiper/turn signal lever StuckInMud94 YJ Wrangler Technical Forum 3 08-06-2005 11:49 AM
