How do I replace a fuel pressure regulator in jeep? - JeepForum.com
post #1 of 6 Old 08-19-2010, 08:06 PM Thread Starter
CrawlerYJ
Anyone have a video or pictures on how to replace a fuel pressure regulator on jeep 4.0l?
Thanks
CrawlerYJ is offline
post #2 of 6 Old 08-19-2010, 08:12 PM
Apollo12227
VERY easy...
Step 1: Relieve fuel pressure via the fuel rail... There is a cap on the fuel rail, inscrew it, push in the valve and release the pressure.
Step 2: Remove the single vaccum line from the regulator.
Step 3: Unscrew the single bolt holding (clamping) the fuel pressure regulator to the fuel rail.
Step 4: Pull pressure regulator out of the socet, and push in the next one. Use a tad bit of grease on the o-ring to keep it from cutting, drying out, etc...
You can TEST the fuel pressure regulator. All you need is to rent a fuel pressure tester. As your reading pressure at idle, pull the vaccum line off the regulator and the fuel pressure should INCRASE by 7-8PSI... if it fails to increase the regulator is bad.
Another test for the fuel system is to pinch the return line shut momentarily, if the fuel pressure shoots up to 70-90psi then your fuel pump is functioning at acceptable pressure as well.
Apollo12227 is offline
post #3 of 6 Old 08-19-2010, 08:17 PM Thread Starter
CrawlerYJ
Found it. Front of the fuel rail. Looks simple to replace.
Question? Remove gas cap, start, pull fuel fuse? Then replace FPR?
post #4 of 6 Old 08-19-2010, 08:21 PM
Apollo12227
Um.... no need to remove the cap, just follow what I wrote lol... Relieve the pressure at the rail, take out the bolt, pull out the PR, insert new regulator, put bolt back in, start jeep...
Not sure what your missing within step 1, 2, 3, and 4...
(Edit: The release valve works/looks kind of like a car or bycycle tire valve... Push it in with a screwdriver, let the fuel spray out, clean up the mess, and continue.)
post #5 of 6 Old 12-05-2013, 04:12 PM
jgregory6375
Is this the same on a 92 ??? Thankyou
jgregory6375 is offline
post #6 of 6 Old 12-06-2013, 08:51 AM
TSEJEEPERS
yes
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
Fuel pressure regulator help. treefiddyYJ YJ Wrangler Technical Forum 12 06-01-2009 11:26 PM
fuel pressure regulator Sfrid073 TJ Wrangler Technical Forum 2 07-22-2005 10:50 PM
Fuel Pressure Regulator Jeepfan Jeff YJ Wrangler Technical Forum 1 04-23-2005 09:15 AM
Fuel Pressure Regulator tclark YJ Wrangler Technical Forum 10 04-12-2005 03:16 PM
Fuel Pressure Regulator JEEPIN_I_AM YJ Wrangler Technical Forum 1 07-07-2002 02:58 PM
