Quantcast How do I Remove Shifter from Tranny? Tranny Brace Question as well - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How do I Remove Shifter from Tranny? Tranny Brace Question as well
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 10-12-2009, 11:02 PM   #1
kgillette
So I'm am in mid process of my clutch replacement and I cant see how to remove my shift lever/shaft:
any suggestions on how to remove it ?
also, in order to remove the tranny I had to cut the bolts holding up the tranny brace to the frame (all bolts where rusted, and if i did get them loose they just spun in the frame) So I am left to face with the issue of some how re-bracing the tranny to the frame (I do not have a welder handy or near by) any suggestions? I was thinking of getting some steel and just making it so it goes across the tranny and u-bolt it to the frame, and then when I can get out to my buddies house and weld something together
88 Wrangler - Build Thread: http://www.jeepforum.com/forum/f12/88-yj-fix-turned-build-956202/#post8758947
kgillette is offline   Reply With Quote
Old 10-13-2009, 06:18 AM   #2
kgillette
none?
I have the book, and it offers no useful suggestions. it says the shift lever is suppose to be a push and turn counterclockwise on the base of the shifter.
Old 10-13-2009, 07:12 AM   #3
kgillette
from thread: http://www.jeepforum.com/forum/f12/take-off-transmission-change-slave-cylinder-820824/index2.html#post7631355
Originally Posted by Mean Max View Post
It looks like three bolts hold it in to me.
Max
After I take the 3 bolts/screws out (which i have done) , should I pull up? Ive been looking and some threads say that there are suppose to be snap ringss, Im not seeming them on mine, but I guess I could clean it up a bit better and see if they are just hidden
Old 10-13-2009, 07:21 AM   #4
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I am looking thru the info I have now. I know the AX-15 is a push down turn and pull up setup but I am fairly certain that the BA-10, what you have, is bolted down.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 10-13-2009, 07:52 AM   #5
kgillette
So once its unbolted I should be able to just pull it out?
Old 10-13-2009, 09:57 AM   #6
rustywrangler
as far as I know yes.
Old 10-13-2009, 11:48 AM   #7
Haybusters
Junior Member
your shifter should pull straight out after removing the three bolts just did mine last week during a t-case change. from your pic it appears you have alot of krud around yours, might give it a shot of PB or WD-40
Haybusters is offline   Reply With Quote
Old 10-13-2009, 05:34 PM   #8
kgillette
I cleaned a good portion of the crap out from around where the shaft goes in... I sprayed a whole bunch of PB around the base of the shifter and surrounding and let it soak. It wouldnt pull, I got it to budge a-little but no more then 1/4inch, so I put a pry bar and try'd to pop it off with no success.
Should I just more PB and let it sit longer?
This damn lever is killing me, thank god its only going to be cold and not rainy tomorrow (motorcycle is my only other vehicle)
Old 10-13-2009, 06:21 PM   #9
kingcn
I had the same problem on a BA10 swap, it was rust frozen in. Luckly my new-used one came with a shifter. I think your best bet is to take a torch to it to try and use heat to break the rust bond.
_____________________________________________
Front: Dana 30 4.10: Yukon Chrome-molly axles / Super Joints & Lock-Rite locker
Rear: Dana 35 4.10: Yukon Chrome-molly axles & Lock-Rite locker
C & C Fab Tube Fenders (giving these guys a plug because they treated me so well)
Home brew oil-pan/bell housing skid plate and gas tank skid plate.
kingcn is offline   Reply With Quote
Old 10-13-2009, 08:22 PM   #10
kgillette
thanks for the suggestion. I'm letting it soak in PB for the night, Ill respary in the AM and then after work if it doesnt come out I'll bust out the torch.
Old 10-28-2009, 04:25 PM   #11
kgillette
After tugging, heating, pb blasting I got the shift lever off. the catch, the retainer clips stayed in as well as the sealer/hold-down (see pic below, arrows are pointing to and on the piece)
any ideas on getting it out? Ive been heating and pb soaking the beating (well really just tapping) hell-outta it. not a budge though...
Old 10-28-2009, 08:54 PM   #12
kgillette
well according to this post:
Originally Posted by TheNerd View Post
...also, you realize that if you want to do a "proper" boot install, you will need to separate your 2-piece shift lever to get the dust boot on, then you will need to get it back together... IIRC, when I was looking for mine, they only sold the whole assembly (shift lever w/boot) as a unit.
Here is a pic of the shifter removed. The rubber piece is all that was left of the boot. Notice the giant hooch you need to get that little rubber hole over....
I still need to get the rest of my shifter out... which totaly sucks, as I need this thing working for a trip tomorrow..
Old 10-28-2009, 08:55 PM   #13
kgillette
any suggestions on how i do that?
Old 10-29-2009, 10:36 AM   #14
kgillette
crows foot (or feet) and a large washer = out in 10minutes
everything else i tried before = 5hrs not a budge
Old 10-29-2009, 11:12 AM   #15
flame0086
That metal flange looks like some sort of dust cover to me. My mazda had something similar for the drum breaks. Ended up ****ing up a small flat head screw driver while I used a hammer and chiseled away at it. Some PB blaster around the edges would help loosen up the gunk, but I don't know if you want PB getting into your transmission.
100 mpg!! Western Washington Univeristy X-Prize Team http://wwuxprize.blogspot.com/
Support Search and Rescue
Get Lost
flame0086 is offline   Reply With Quote
Glock Forum
