How do I remove the shifter for my transmission itself - JeepForum.com
post #1 of 21 Old 10-25-2009, 01:39 PM Thread Starter
Goobersbro
I am stripping the inside of my jeep and I am curious as how to remove my stick shift??? Mean max help hahaha
My marshmallow build
Goobersbro is offline
post #2 of 21 Old 10-25-2009, 03:33 PM
Alfons
There are a couple of ways assuming you have the upper boot (there are 2 of them, the accordian shifter boot and a flat rubber seal (this I call the lower boot) that covers the whole opening) and cover plate removed:
  • Undo the 4 bolts on the shifter pedistal and lift it all off.
  • Inside the pedestal, there's a bayonet fitting on a spring that holds the shifter inside. You need to push down & turn it (counterclockwise I think), then pull the shift lever out - the lower boot will stay on unless you cut it or split the shifter (the bottom of the shift lever is pressed into the upper part).
Alfons is offline
post #3 of 21 Old 10-25-2009, 03:35 PM Thread Starter
Goobersbro
thank you I will go try that
post #4 of 21 Old 10-25-2009, 03:55 PM
moonshinefuel
opihi59 did a nice write up on removing the shift lever.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #5 of 21 Old 10-25-2009, 10:51 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Gotcha covered Goob!
Here is the shift tower. The shifter lock ring engages the 2 pins in the sides of the tower and the seal sits at the bottom to provide a seat for the ball on the shifter. If the seal is bad, replace it, the pins are not removable, but the oil seal can be installed while they're in place.
Shifter removal includes unlocking the retainer ring from the base, also check the small hard nylon cap at the very tip of the shifter for wear.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 21 Old 04-18-2010, 01:27 PM Thread Starter
Goobersbro
so I tried and tried pushing down and the thing won't friggin budge but I can lift it up like a solid 1/2 an inch or more also which way do I rotate it for sure....because this thing isn't moving like What the crap
post #7 of 21 Old 04-18-2010, 03:59 PM Thread Starter
Goobersbro
ah ha I figured it out hahahaha it wasn't the stick itself you guys were talking about it was that little metal piece I figured this out after reading max's post over and over and over again lol anywho thanks I got it out and cleaned it all up and put it back in
post #8 of 21 Old 05-19-2010, 10:27 PM
normalicy
1987 YJ Wrangler
OK, so I figured out how to detach the shifter per this post (was just as confused as Goobersbro). I didn't realize that the shifter & can looking thing weren't connected. However, I'd really like to know how to seperate these two pieces so I can remove the old boot & install a new one without cutting? Short of brute force (which I guess I don't have enough) I can't get it separated in a logical manner.
What is normal anyway?
E-mail at:
Heatware References (a feedback website)
Ebay Feedback
normalicy is offline
post #9 of 21 Old 05-19-2010, 11:04 PM Thread Starter
Goobersbro
I got my boot off without destroying it but honestly don't know how it took me a solid like 20 minutes of pulling and being angry and sitting and staring at it and then trying some more hahahhahaha....Finally I got it thought
post #10 of 21 Old 05-19-2010, 11:09 PM
1990offroadYJ
the onlyk way i was able to get mine off was to use a air hammer and a vise. and it bent the can peice a little. it was a pain
1990offroadYJ is offline
post #11 of 21 Old 05-20-2010, 12:06 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Try this link from the FAQ.
http://www.jeepforum.com/forum/f12/s...hifter-513891/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #12 of 21 Old 05-20-2010, 01:58 AM
normalicy
1987 YJ Wrangler
Awesome thinks. I looked all over for this info & couldn't find it. Brute force then. Gonna have to get a pickle fork.
E-mail at:
Ebay Feedback
post #13 of 21 Old 12-08-2010, 08:27 AM
jwheels627
This thread came up as the closest thing i could find, does anyone know what peice is the washer/seal that holds the ball of the shifter down in the transmission?
I didnt do the work, but my poor mechanic doesnt know the name of the peice and showed me mine which was worn and in pieces...all he could say was its a curved washer the holds the bottom ball of shifter.
Any help is well appreciated...staring to snow so i really need my jeep running
jwheels627 is offline
post #14 of 21 Old 12-08-2010, 08:58 AM
normalicy
1987 YJ Wrangler
You're probably talking about part# CRO4864226X as sold here:
Oil Seal by Crown Automotive and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH3
E-mail at:
Ebay Feedback
post #15 of 21 Old 03-07-2011, 12:42 PM
TrentYJ
Hey guys I got a major problem doing a clutch swap and the ring holding the shifter retainer is absolutely not moving and I can't get the shifter off. There's a lot of crap in there and I guess it's all corroded but there's no way any sized man could get this down and twisted. I used about a gallon of PB and it still won't move. Do u guys have any suggestions or experiences with this bc I can't go any further with this until that shifter comes off.
"Arguing over the internet is like running in the Special Olympics...Even if you win, you're still retarded."
-François-Marie Arouet
TrentYJ is offline
How do I remove my TJ's Shifter Knob? Modfatha TJ Wrangler Technical Forum 29 12-11-2016 06:22 PM
how to remove shifter knob??? PITBULL1967 TJ Wrangler Technical Forum 23 12-03-2012 10:39 PM
How to remove/bend shifter? Srhmn8r TJ Wrangler Technical Forum 4 03-12-2007 06:27 AM
How do I remove shifter (pics)tuffy vs. BL derek45 TJ Wrangler Technical Forum 21 10-29-2005 12:16 PM
how do i remove shifter knob bigdog67 TJ Wrangler Technical Forum 4 03-25-2004 08:01 PM
