How do I know if my suspension could use replacement? - JeepForum.com
post #1 of 4 Old 06-08-2013, 04:55 PM Thread Starter
rocksnstuff
I know this is a broad, if not vague, question. Here is some more detail:
I just bought my first Jeep. It is a 1993 Wrangler. I am pretty sure it is rocking all of the original suspension. There are no cracks or excessive rust in any of the leaf springs.
All four leaf springs (front and back) sit pretty much straight when the vehicle is not weighted (no passengers), with a bit of sag on either end of the spring where it attaches to the body. Is that normal, or a sign that the springs are getting worn? I have been sneaking peaks at other Jeeps' suspension and noticing most leaf springs are still concave, crescent shape facing up with the weight of the Jeep body on them.
What visual cues should I look for? How should the ride feel? Is there no better way to determine if they need replacement than to take it in to a mechanic who is familiar with Jeep suspension?
Thanks!
rocksnstuff is offline
post #2 of 4 Old 06-08-2013, 05:03 PM
Michaelgoesrawr
They are probably the original springs which were flat from the factory. The arched springs are lift springs.
At this point they don't necessarily need replacement, I have the stock springs on my '88, but a set of Old Man Emu springs will help your Jeep ride like a Cadillac(from what I've heard anyhow)
Michaelgoesrawr is offline
post #3 of 4 Old 06-08-2013, 05:15 PM
BEETROOT
Unless they are badly rusted or you can see cracks or something in them, they should be fine. Like the other poster said though... new springs would probably give you a better ride.
BEETROOT is offline
post #4 of 4 Old 06-08-2013, 07:17 PM
Noltz
YJ Wrangler
Confirming new springs are virtually flat. OME had a reputation of best riding springs. BDS has the lifetime warranty 2.5 or 4" springs if you're lifting it.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
suspension
