How do I get the side panel off? - JeepForum.com
post #1 of 6 Old 01-01-2012, 06:25 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
I need to replace my door and entire left side panel after getting broadsided. How do I get the side panel off? Talking the entire side from just behind front wheel to the back corner panel. I have never done body work before so I don't even know where to start.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #2 of 6 Old 01-01-2012, 06:33 PM
bharris68
Daily Driver
Can you show pictures? There are panels up front but the back is a Tub that I am aware of.
bharris68 is offline
post #3 of 6 Old 01-01-2012, 06:35 PM
ZeroGravity
First of all get a Haynes repair manual.
The sides are spot welded in place. You will need to drill out each spot weld in order to remove the panel.
These are both good resources for factory original body parts/restoring a tub:
http://www.classicent.com/jeep.php
http://www.quadratec.com/category/Je...s/41/index.htm
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #4 of 6 Old 01-01-2012, 06:36 PM
ZeroGravity
I'm sure you know what a Jeep tub looks like. "I need to replace my door and entire left side panel after getting broadsided." sorta lead me to believe he's talking about the entire side of the Jeep.
91 YJ
98 XJ
2 door love
post #5 of 6 Old 01-01-2012, 06:55 PM
roadyrob
1987 YJ Wrangler
you will probably get more info posting on the paint and body section of the forum, but like the other poster said the panel is held on with spot welds. you don't drill out the weld, you use a special cutter, its like a hole saw bit that is slightly larger than the weld and it cuts around the weld. you will have to cut away the damaged panel to get access to the welds, a 4' grinder with a cutting blade will work for this. after you remove the old panel you grind down the welds, drill holes in the panels for the new welds, then weld it in with a mig.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #6 of 6 Old 01-01-2012, 07:20 PM
ZeroGravity
I've seen those tools before, the drill works fine though. It's on my list but there are a million other things I need before it. I figure a drill bit is more common in someone's toolbox. Flux core is just a suitable for body work as mig.
Use a wire wheel to remove any filler/paint and locate spot welds.
91 YJ
98 XJ
2 door love
Best Top Supertop Side Panel Storage oaklane JK Wrangler Technical Forum 0 06-21-2010 01:02 PM
Soft top side panel storage daddyscooltv Wrangler General Discussion 9 11-15-2009 09:10 PM
06 Rubicon Side Panel shmeeny TJ Wrangler Technical Forum 6 03-30-2006 09:25 AM
Sahara side panel install. OlllllllO Jeep1 TJ Wrangler Technical Forum 0 09-05-2005 02:41 PM
