How do i get more flex from my leaf springs - JeepForum.com
post #1 of 76 Old 02-14-2013, 06:43 PM Thread Starter
Taylor_44
I have a 2.5' with 32's and I can't get it to even flex to the bump stops. Any suggestions as to why and how to increase the flex without installing a new lift kit?
Taylor_44 is offline
post #2 of 76 Old 02-14-2013, 06:49 PM
dillonjm
2013 WK
You have to disconnect your front swaybar, it is designed to prevent one side from flexing without the other, great on road, they need to be disconnected when you go offroad (or in a YJ you can remove them altogether, I never ran them on my YJ).
Also, get rid of your trackbars.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 76 Old 02-14-2013, 06:55 PM Thread Starter
Taylor_44
I went and looked at my sway bars and it looks as if they are bent aft and hitting the axle.
post #4 of 76 Old 02-14-2013, 06:58 PM
jbolty
jbolty's Avatar
What he said. ^^^
Plus, what springs do you have?
jbolty is offline
post #5 of 76 Old 02-14-2013, 06:59 PM Thread Starter
Taylor_44
I'm not sure, the PO put the lift on. It has Rancho shocks though
post #6 of 76 Old 02-14-2013, 07:01 PM
dillonjm
2013 WK
They still have to be disconnected off road or else that's as much flex as you're going to get, regardless of springs.
dillonjm is offline
post #7 of 76 Old 02-14-2013, 07:28 PM
TSEJEEPERS
Get rid of the sway bar too, front and back.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #8 of 76 Old 02-14-2013, 07:31 PM Thread Starter
Taylor_44
I have front and rear spartan automatic lockers, will the combination of automatic lockers and sway bars make a dangerous combination? (I still have to drive on the highway at highway speeds to get to my trails)
post #9 of 76 Old 02-14-2013, 07:42 PM
TSEJEEPERS
Sway bar disconnects are cheap and easy to install.
Hopefully someone will post up one they made by themselves.
post #10 of 76 Old 02-14-2013, 08:42 PM
b_a_mech
Disconnects are the way to go for you. I drive on the hwy too and just disconnect when I go off road. Just lose the track bar, keep the sway bar and install disconnects
BUILT NOT BOUGHT #602 / ZOMBIE RESPONSE TEAM #40 / USN HULL #196
b_a_mech is offline
post #11 of 76 Old 02-14-2013, 09:00 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Just get rid of it all. Trackbars and swaybar. I thought I was going to need some disconnects for my revolvers but they ride nicer on the freeway than the boomerangs.
You'll be fine.
Luck Favours The Prepared
Anticanman is offline
post #12 of 76 Old 02-14-2013, 09:07 PM
dakota123
Take both your sway bar and track bar completely off you dont need em what so ever even on the road.
dakota123 is offline
post #13 of 76 Old 02-14-2013, 09:09 PM Thread Starter
Taylor_44
You'll be fine.
Are the revolver shackles live up to the hype and worth the money?
post #14 of 76 Old 02-14-2013, 09:12 PM
kjg26
kjg26's Avatar
Everyone I've talked to about revolvers didn't like them. Said they were unpredictable
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #15 of 76 Old 02-14-2013, 09:13 PM
kjg26
kjg26's Avatar
2.5" OME springs, 5/8 lift shackles, 1 inch body lift. No track bars and no sway bars
kjg26 is offline
