how do i fix my 4 wheel drive - when in 4wheel drive only one wheel turns
#1 | |
as i was 4wheeling i came up on a hill that came to a point my car teetered and i threw it in 4 low but nothing happened my left back tire was the only one moving how can i figure out the problem and get it fixed
#2 |
Search for vacuum disconnect or 4x4. Lots of threads if its not engaging. Also try searching posi lok or tj shaft upgrade. As far as 1 tire spinning in the back, you probably have an "open" differential.
#3 |
If you want all 4 wheels to grab,gotta install lockers
White 90 YJ...Soft/Hardtop, 31" BFGs, 3.5" lift, Rebuilt 4.2L, Weber 34/34, Herc'd LOOKING FOR 4cyl axles F/R, 4.10s, will trade for my 3.07s complete
Also need 16x8 rims with less backspacing |
#4 |
I'm with lblair04, search for threads about vacuum actuator, or4wd not engaging.. sounds like your vac actuator stopped working. It's up front on your axle housing closer to the pass side. also check & make sure it's still plugged in also. cause i was flexing out and my vac hoses pulled off. good luck!!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
