How do I find out what size lift my YJ has? - Page 2 - JeepForum.com
 1Likes
post #16 of 18 Old 08-24-2010, 04:29 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Originally Posted by T-ray View Post
So, 23" from floor to panel, tires are 2.5" higher over stock, 23-2.5= 20.5 or a 2.5" lift? OK so where can I find this lift. I've never had anyone show me where the actual lift brackets are.
There are no "lift brackets". A suspension lift on a YJ is done with either new leaf springs with a larger arch or with new shackles that are longer. (not to mention a spring over axle (SOA) setup - too confusing at this point in the thread)
It looks like you have about a 2" to 2.5" lift that is accomplished with after market springs and also after market lift shackles on the front end to level out the Jeep.
-John-
johnboy68 is offline
post #17 of 18 Old 08-24-2010, 06:02 AM
mattyrayb
If you're factoring in the height of the tire you wouldn't subtract the total difference, only 1/2 that right?
For example, stock tires being 29" and an aftermarket set being 33" the difference would be 4". BUT you should only factor in the radius (center to outside edge) which gives you 2" of extra lift. The other 2" is just on top of the tire not making a difference to overall height.
At least that's my thinking.
jeff06220 likes this.
mattyrayb is offline
post #18 of 18 Old 08-24-2010, 07:47 PM Thread Starter
T-ray
Cool, thanks for the info. The front shackle does look longer but I havent seen a stock one to compare it too.
T-ray is offline
Lower Control Arm bolt size? Has TuffCounty lift but I believe bolts are stock size. SolidBrass TJ Wrangler Technical Forum 10 11-09-2010 09:00 PM
cant find tire size online anymore CreepyCrawler95 YJ Wrangler Technical Forum 12 04-26-2009 08:32 PM
TPS or something else, help me find the right size radiator bolt veritas4156 YJ Wrangler Technical Forum 8 01-24-2008 07:29 PM
best way to find out what size lift? AK1904 YJ Wrangler Technical Forum 3 07-31-2003 12:10 AM
Can't find my rim size... RobC TJ Wrangler Technical Forum 4 07-14-2002 01:21 PM
