How do I determine my body lift? - JeepForum.com
post #1 of 6 Old 11-04-2011, 10:44 AM Thread Starter
tchoberg
1987 YJ Wrangler
I just bought a '87 4.2 Liter YJ that has a raft of extras, 33 x 12.5 tires with 1 1/2" or 2" spacers, brushgard with driving lights, custom bumpers with a swing out rear with jack and luggage mount, Kenwood AM/FM/CD radio, hard top, full doors, and it is lifted. The only problem I have is that 33's rub the springs when I turn hard, which isn't a big deal.
My question is - how can I figure how much lift do I have?
Thanks - Ted
tchoberg is offline
post #2 of 6 Old 11-04-2011, 11:01 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Thanks - Ted
post pictures of it. good pics from the side and rear.
there is a bolt on each knuckle up front. it is your steering stop. if you back it out a few turns, you can get to where it hits the steering stop before the tires touch the springs. take a look
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #3 of 6 Old 11-04-2011, 11:08 AM Thread Starter
tchoberg
1987 YJ Wrangler
Hi Poke - Thanks for the information on the steering stops. I will check them out and take some pictures and post them tomorrow as it is raining here today.
Ted
tchoberg is offline
post #4 of 6 Old 11-04-2011, 11:11 AM
Alfons
If the tires were installed on OEM rims, you most likely have the wrong backspacing. By limiting your turn radius with the adjustment Poke suggested, you will be able to stop this but you'll end up with a larger turn radius.
A body lift won't move the tire away from the spring.
Alfons is offline
post #5 of 6 Old 11-04-2011, 11:11 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Often the spring manufactures with paint a part number on the top of the leaf spring. You may need to clean it some or brush the dust off of it to clearly see the number.
Google that number & you may find that leaf to be part of a lift kit.
Check the shackles too to see if they are lift shackles.
Stock shackles are 4" from bolt hole to bolt hole. 1" lift shackles will be 6" between holes. 1/2" lift shackles would be 5" between holes etc etc.
Joe Dillard is offline
post #6 of 6 Old 11-05-2011, 10:47 AM Thread Starter
tchoberg
1987 YJ Wrangler
I will check all that was suggested but it snowed will delay me. Good info - Thanks
tchoberg is offline
I'm trying to determine how much lift this Jeep has gary1 TJ Wrangler Technical Forum 7 10-27-2010 09:26 AM
determine the amount of lift that I have TJsport33s TJ Wrangler Technical Forum 36 12-12-2009 01:35 PM
How do I determine my leaf spring lift? wb2510 YJ Wrangler Technical Forum 4 12-08-2007 07:21 AM
Help determine my lift Monrozombi TJ Wrangler Technical Forum 20 02-13-2006 07:53 PM
how to determine how much lift you have? farinspace TJ Wrangler Technical Forum 2 03-10-2005 06:53 AM
